Old 09-17-2018, 08:46 PM
backroadin''s Avatar
XJ spring shackle dimensions?
Can anyone tell me what the width's are on a stock xj/mj shackle? Width at mounting end and width at spring end. Also, are they 9/16" bushings?
My '73 has an inside width of 2.5"+ at the shackle hanger and 2 1/2" springs. Need some new shackles and don't want the longer chevy ones. I've found plenty of choices that are the right specs except for being too wide at the shackle hanger, and I can't seem to find that info on the xj ones.
Thank you!
Old 09-18-2018, 07:36 PM
FleetFox FleetFox is offline
from a stock j10 shackle. I bot new XJ shackles to replaces these
spring end, inside diameter: 2.625 " +/-
bushing end: w/ bushing in outside diam: 2.875"
steel only outside diam 2.375"
the XJ shackles were like $16 new, each.
Hope it helps.
FleetFox
Old 09-18-2018, 07:40 PM
Bushing ID was .5 on both ends btw
Old 09-19-2018, 03:23 PM
Awesome - thank you!
Old 09-22-2018, 07:16 PM
skeletor's Avatar
skeletor skeletor is offline
I had xj shackles on for a little while and they work, but I didn't like how much more I had to torque down the frame mount to to get the bushing snug, it looked pinched. maybe I had some weird xj shackles, but the bushing was way more narrow and the upper part of the shackle barely cleared the bottom of the frame mount. i ended up getting actual replacement fsj shackles, which are definitely better. my 84 is probably a little different from a 73 though.
-bryan
1984 j10 LWB
1977 Cherokee chief wide track(sold)
2004 LJ
Old 09-23-2018, 09:34 PM
Yeah, I ended up getting some ford shackles (E747-43). Still not ideal but they work. They're a little narrower at the bushing end than the XJ's, which I need and they're 9/16 I.D. too. Still needed to spread the frame mounts a bit.
Different spring set up on shackle flip fsj4life Off-Road FSJ Tech 11 11-16-2011 07:56 AM
Front Spring Shackle Question... Frank General FSJ Tech 2 12-06-2010 01:08 AM
Spring Hanger / Shackle Lift ? Ziptie Off-Road FSJ Tech 19 09-05-2008 11:37 AM
(TOM) Spring replacement lifts Sitting Bull Suspension and Steering 0 10-02-2001 02:06 PM
Rear spring shackle bolt HELP! Ralph General FSJ Tech 12 11-12-2000 05:11 PM
