Old 03-26-2017, 08:30 AM
63J200atLSU's Avatar
63J200atLSU 63J200atLSU is offline
Originally Posted by itselliot
https://www.dropbox.com/s/jpelevmb5i...0side.jpg?dl=0
Drivers side,.... starting to look like my vision.....
Holy crap that truck is going to be great! Can't wait!
'63 J200 Resto-mod in progress
(http://www.ifsja.org/forums/vb/showthread.php?t=178651)
If all goes well, we can toast to accidental successes.
I'm convinced I'm just too dumb to know that I can't restore this old truck...
Old 03-26-2017, 09:46 AM
Frank Ziebert's Avatar
Must have missed something. Where did the inserted section come from?
Old 03-26-2017, 10:18 AM
SJTD SJTD is offline
The bed?
Sic friatur crustulum
Old 03-26-2017, 04:34 PM
itselliot's Avatar
Yup
The bed in the foto is a 7' bed I found in Wi thru a member here...just happened to be the same color.
The original 8" bed is a donor now....BTW the rear flares from the donor will be available and they are not too bad either...just sayin'
hpschrot@hotmail.com
616 four 03 44 0 five
Old 03-28-2017, 09:55 AM
Sweet! The color match threw me a bit
Old 03-28-2017, 02:46 PM
itselliot's Avatar
little further
few more fotos on the progress...pretty soon the rockers will arrive and , once welded in the cab can come off. and new (to me) doors will be installed.
https://www.dropbox.com/s/xgbuel1icn...1404c.jpg?dl=0
https://www.dropbox.com/s/dju1tzrst6...1404a.jpg?dl=0
https://www.dropbox.com/s/h75xvgij8x...1404b.jpg?dl=0
The doors to be removed, will supply the window framing in the rear , stationary glass. and then an OEM slider in the back.
Old 03-28-2017, 05:31 PM
Is the roof skin fabed or grafted from something else?
Old 03-28-2017, 06:14 PM
itselliot's Avatar
I found a complete roof then cut out the middle for the 13" extension. There is a slight taper to the roof line..so it worked out pretty well.
The brow and back section of the donor roof are available to anyone that would want it.
Old 03-29-2017, 07:54 AM
bkilby's Avatar
bkilby bkilby is offline
Wow, nice work! That's going to look great when it's done.
Old 03-29-2017, 09:10 AM
Like I said: I wish I had never seen this thread!
I assume you used a donor floor section also?
Old 03-31-2017, 03:41 PM
itselliot's Avatar
update 3/30/17
summor fotos
Inner rocker
https://www.dropbox.com/s/0xqbvsip1e...71325.jpg?dl=0
rear fixed window rough in
https://www.dropbox.com/s/lzeqzbv6vx...1325a.jpg?dl=0
passenger window, looking from the inside out.
https://www.dropbox.com/s/pee4qaabwh...1325d.jpg?dl=0
Passenger side outer rocker used 2 door Cherokee rocker from Nor Am parts.
https://www.dropbox.com/s/5oxpka7jf7...71326.jpg?dl=0
Old 03-31-2017, 04:42 PM
itselliot's Avatar
I wish..... However..floors will be plate steel.....I'm practical and a little "frugal" if possible.
Old 03-31-2017, 07:12 PM
itselliot's Avatar
Thanks,....have you been able to get some more info on the sheetmetal?
Old 04-04-2017, 10:42 PM
Randyzzz's Avatar
Randyzzz Randyzzz is offline
This is looking great. I've threatened to do this to mine...
Randy S.
It's not what you Buy, it's what you Build.
1987 J20
1965 J2000
1966 Waggy
1968 Waggy
1970 Waggy
1972 Waggy
1982 Scrambler
1981 Scrambler
www.oldsoulsretros.com
Old 04-05-2017, 05:52 PM
itselliot's Avatar
its coming along
The cab extension seems to be the most simple aspect of this project...
The seating and interior detailing are beginning to become difficult......I would love to be in an area that isn't rusted away...I envy you west coasters.......Anyone have a bucket seat from a 2 door FSJ????
Old 04-06-2017, 08:20 AM
Thumbs up
Just musing around-----that would make a neat 5 window.
Old 04-08-2017, 10:00 AM
itselliot's Avatar
interior
Just came back from the bone yard...........found a 2001 Dakota extended cab with a tan interior......I plan to use the complete rear seat set up/ side panels and seat base and possibly the front buckets/console for the interior....
got the whole thing including all the seatbelts and OEM scissor jack that fits in the rear base for $225.............pictures will follow ....keeping my fingers crossed on the front seat base matching up to the GW power seat bases.
Old 04-08-2017, 01:52 PM
Great find. Really interested if they will fit the base.
Old 04-11-2017, 08:33 AM
itselliot's Avatar
and on it goes
The frame hit the floor this week Rebuilding the front D44 and paint.
https://www.dropbox.com/s/zn15d8fv16...71133.jpg?dl=0
you may beable to see that the crossmember with the trans hump is no longer in the factory position..we moved it rearward 12" to accommodate the stretched cab
https://www.dropbox.com/s/c94yqqse2z...71258.jpg?dl=0
https://www.dropbox.com/s/62qq91575b...1258a.jpg?dl=0
https://www.dropbox.com/s/y4dopiiilz...1258b.jpg?dl=0
Fotos are of the back of a 98 Dakota ..cab and a half.
The interior is a pretty darn close match up (in size)to a J truck that is stretched 12 inches.
This front seat is a direct fit (bolt up) to a FSJ power seat frame...AND it has forward tilt!!
https://www.dropbox.com/s/8pc23ro4kb...1258c.jpg?dl=0
I grabbed the entire interior 40-20-40 front seats and rear seat/storage box/ full surround trim and the OEM jack and full set of seatbelts for $250
http://www.dropbox.com/s/puz3cddib8z...rend5.jpg?dl=0
Old 04-13-2017, 08:46 AM
itselliot's Avatar
Dakota rearseat install
https://www.dropbox.com/s/9885ihdd27...0seat.jpg?dl=0
rough in of the 1998 Dakota rear seat in the J20
Chero: SO it begins . . . cu4whln General FSJ Discussion 1046 07-05-2017 09:40 PM
Finally!! Tear down begins.... MonsterZ General FSJ Tech 17 03-14-2012 02:55 AM
The rust battle begins mattmopar440 General FSJ Discussion 5 08-27-2008 09:52 AM
Project "Kujo" begins. FSJeeper General FSJ Discussion 6 09-07-2007 08:47 AM
Countdown Begins........... willam General FSJ Discussion 30 07-19-2007 08:11 PM
