Axle build started today...now with pics
  • Merc69
    • Sep 03, 2002
    • 2398
    Well I started the break down of the good 14 bolt. It appears I will be taking the entire axle down. Then new bearings through out. Put the diff back in and install the disc brake setup. While everything is apart I will trim the housing and take the lip off and maybe a little extra.
    I have a new ring and pinion, wheel bearings and u-joints for the Dana 60. Should be here by Tuesday. I plan on that getting started late next week.
    Still have to figure out which high steer arms to go with. Any suggestions?
    Pics to follow soon
    [ August 29, 2004, 11:36 AM: Message edited by: Merc69 ]
  • JeepKahn
    • Mar 21, 2002
    • 803
    Check out www.Sky-Manufacturing.com , that's where I got mine, nice Guy to deal with, Sky that is...
    \"Smoke\'m, They\'ll Stick\"<br /><br />Got Heat Problems???Want Free HP???<br />Check This Out!!!<br /><a href=\"http://www.ifsja.org/ubb/ultimatebb.php?ubb=get_topic;f=3;t=024412\" target=\"_blank\">http://www.ifsja.org/ubb/ultimatebb.php?ubb=get_topic;f=3;t=024412</a><br /><br />Jeremy Kahn [email protected]<br />79 J10Honcho \"SickPuppy\"<br />360,Th400,D20,[email protected],35x12.50s <br />Mobi-Arc on board welder<br /><br />Winston-Salem,NC<br /><br />!!!Will Weld for Gas!!!
    • Merc69
      • Sep 03, 2002
      • 2398
      Well I have the old shock mounts tourched off along with the original spring perches. I spent some quality time with a saws all and a grinder and shaved the pig. What a difference. Have a look
      • Rogue
        360 AMC
        • Nov 17, 2001
        • 3439
        looking good bruce
        PS - if work continues as good as it has then we can continue talking about your 74
        [ August 29, 2004, 11:49 AM: Message edited by: Rogue ]
        • Poley
          360 AMC
          • Mar 22, 2003
          • 2504
          that is nice
          Fullsized Gets it DONE!!!!
          • rockjeep44
            The Advisor
            • Oct 15, 2001
            • 4219
            Bling bling, i love the look of fresh metal
            Buggy Buildup
            Originally posted by welchct
            • Merc69
              • Sep 03, 2002
              • 2398
              Thanks Andrew...I am using one of the BTF 14 bolt covers. That thing appears to be able to withstand bullet impacts.
              • Merc69
                • Sep 03, 2002
                • 2398
                UPS has just dropped off another box...Randys Ring and Pinion is great. Front axle parts and the 14 bolt parts arrived in 2 days.
                Got to love the the fact they have a warehouse in Tenn.
                Now I guess I have work to do [img]tongue.gif[/img]
                • dnixon
                  360 AMC
                  • Jul 28, 2002
                  • 2948
                  Yeah I am going with the sky steering arms aswell.. I really dig them. They are a pretty good price for what you are getting as well.
                  All It Takes Is Money.
                  I'm the reason why you can only have Jeeps for Avatars. You're welcome.
                  • #10
                    Nice work Bruce... coming along nicely.... keep it up...
                    Todd
                    www.ttsfabworks.com
                    • Merc69
                      • Sep 03, 2002
                      • 2398
                      Todd where have you been...that was completed about a year ago. Drove the rig to the ECI this past June...have you been back into the pain meds from the knee surgery
                      • Sambo
                        • Sep 25, 2001
                        • 3585
                        lol i was gonna trim the pig on my 14bolt but decided to let it self clearance alot of rocks out here
                        so what gears are ya going to run???
                        77 chero DEAD.
                        • waggin'ear
                          • Apr 24, 2001
                          • 1269
                          I saw this thread pop back to the front spontaneously like there was a glitch in the matrix.
                          Still makes me feel like I work really slowly though since I know that Merc started his stuff long after I did.
                          adam
                          Gotta a lot of junk
                          " I may not be good, but at least I'm slow"
                          • Merc69
                            • Sep 03, 2002
                            • 2398
                            It has 4.56 gears and Adam is right this phase of the project ended over a year ago. I don't now why it poped back up...I just figured Todd was recovering from sugery again.
                            You know good meds
                            • mudslider
                              • Sep 26, 2004
                              • 2484
                              i know why it popped up LMAO. i posted and then figured my question out and then deleted my post so it stayed. LOL
                              P.J
                              Stupidity rules at all times! Famous last words "Hey, watch this" Its 5:00 Somewhere. 1983 J10 In process: 360 ci install
