Hi Guys,
I sold my Wagoneer last weekend and I am cleaning house. I have a few parts I would give away to a good home.
Air injection pump with pully, belt, and diverter valve
Exhaust manifold air injection tubes, good shape
Rear window slide channel, new never installed
Engine fan, without thermostatic clutch
Front seat mounts with the power motors
Factory 2 barrel intake off 89 GW
Oil pan gasket
rear main seal
Timing chain set, narrow
Valve stem seal set
Other misc engine gaskets
You guys have all been such a great inspiration and help over the past 3.5 years, just wanted to give back a little if I can.
Thanks, Russ
Oil pan gasket
rear main seal
Valve stem seal set
Thanks, Russ
