Manual Lock-Out Conversion ?
  • Reanman
    • Feb 08, 2006
    • 4
    Brand new FSJer here. I purchased a 1990 Grand Wagoneer last weekend. I am looking into the manual lock-out conversion for my FSJ, but have been unable to clearly identify my transfercase. Anyone know how I can identify what I have. And if this conversion is a possibility for my FSJ.
  • J10Mike
    Delightfully Incompetent
    • Jun 04, 2003
    • 5811
    welcome aboard. if it's original, your transfer case should be the np229 case. there is a round tag on the back of the tc. it will have the tc model number.
    i personally wouldn't put lockouts on a np229 rig. but, others have.
    www.j10mike.com
    • Reanman
      • Feb 08, 2006
      • 4
      What are the pros vs. cons of swapping to manual lockouts? I had heard that you can save on fuel economy with the swap and since I plan on using this as my daily driver....manual lock outs sounded like the way to go.
      • Texas ChE
        • Jan 01, 2006
        • 47
        Welcome. I am also new to all this and just purchased an 87 GW that had manual hubs installed by a previous owner. The 87 also has the New Process 229 case that yours should have. To make a long story short, if you run the transfer case in 4hi with the hubs unlocked, you will damage the viscous coupler in the transfer case. This is a very expensive part, and is what allows the ability of running full-time 4hi (allows slipping of front axle during turns in 4wd). Mine is apparently damaged and has been pinned. I can only run 4wd off pavement.
        1987 Jeeep Grand Wagoneer, Edelbrock Performer intake and Edelbrock 1406 carb, Rancho HD AAL, more to come! David R. Garcia
        • J4GRAND
          J4000 Restoration Specialist
          • Apr 09, 2000
          • 5937
          It is difficult to raise the mileage on a rig that has the aerodynamics of a barn. You'd be better off spending the money you would on hubs and doing some ignition upgrades such as the TFI upgrade. Do a search if you're wondering what that is.
          Patrick V.
          MEMBER #14
          78 Cherokee Chief WT "Old Blue" 360 V8 4V TH400 QT RIP
          • #6
            if i were you i would NOT put lockouts on it .
            85 gw 215k and still going
            89 gw,free,almost legal
            • 89grand
              Resident ***hole
              • Feb 23, 2003
              • 5667
              I agree, don't do it. The mileage gain would probably only be something like .045 miles per gallon. So instead of 10mpg, you'd get 10.045.
              Besides, when you accidently toast the t-case, that .045mpg gain will seem even less worth while.
              Steve
              1989 Black Grand Wagoneer, BJ's 4" lift, ProComp ES3000's
              31x10.5x15 BFG AT KO's,MSD 6A,TFI upgrade,360,727,229,2.72 gears.
              2006 Dodge Magnum R/T
              2000 Jeep Wrangler
              1988 Cadillac Brougham
              1966 Dodge Monaco 500 383
              1965 Pontiac Tempest 326
              • #8
                yea at 400$ min. to replace the coupling alone,it would take a long time to pay for it in gas savings
                [ February 10, 2006, 12:15 PM: Message edited by: talntar ]
                • Reanman
                  • Feb 08, 2006
                  • 4
                  Thanks for the info. I was reading the article on the manual lockout upgrade on the BJsoffroad website. I had read that this upgrade was not recommended for certain tcases and was unsure if I fell into the latter category. Thanks for the advice. The TFI upgrade looks pretty simple. I'll get to that after I change out the rear axle bearings on the D44.
