I am replacing the steering gear box in Janies Honcho, she wanted to switch to a gear box out of a J-20 instead of the J-10.
I have always refered to the joint between the steering column and the geear box as a steering gear rag joint, but so far the idiots at Auto not go there Zone can't find anything.
Anyone have any ideas? The old one off the Honcho is a smaller diameter, and will not open up wide enough to fit on the input shaft of the gear box.
The other ? is this, if I do in fact find the correct joint for the gear box, will it fit the lower steering shaft of the J-10?
Thanks in advance.
Bill
Thanks in advance.
Bill
