I believe my dash cluster is having issues...the gas gauge and amp gauge both are not registering correctly and many of the lights that normally light up appear to be burned out. Fuses check out good, etc, and will of course check the fuel sending unit, etc for issues but more than likely dash cluster needs to be replaced.
However, my question is this.....
The chime that is normally heard when you turn the key on to remind you to buckle your seat belt....where is that chime located in order to troubleshoot why it might not be working? Is it part of the dash cluster or is it somewhere else?
Thanks!
Thanks!
