Old 05-18-2019, 11:04 AM
jumpin_jumpin jumpin_jumpin is offline
Dug the project out- still have an HG issue to resolve. Thoughts?
OK so long story short, restored for my sister an 87 Grand Wagoneer. Drove it out to Montana and that seemed to be the last of it's life. Her HOA wouldn't let the car sit in her driveway so it was in a field all winter. It's now back home, ready to be towed from shop to home to shop and back.
A few mechanics have confirmed that the head gasket is blown, and last time we went to start it there was a brutal grinding that I can only assume is a damaged flywheel grinding on the starter.
Shop quoted a few thousand to repair the head gaskets. My brother in law bought a new engine, but apparently it would be too much work to convert that engine to the Jeep so that's a money sucking option too. Original engine has about 155,000 miles on it.
SO
Question is, how hard is it to do the head gaskets? I can't get out to Bozeman for another month and a half to even attempt it.
Should we look for another (actually compatible) engine?
Pay to have the original one repaired?
Or try the repair on my own?
What to do about the grinding noise?
Old 05-18-2019, 11:58 AM
Head gasket is stupid easy to replace...few thousand = hwy flippin robbery.
for grinding roll motor over by crank bolt and try again.
probably have to inspect to see if flexplate is done?
1994 Caprice wagon
Old 05-18-2019, 12:17 PM
Changing head gaskets is a PITA specifically for your back but it's not high tech difficult. More labor time/grunt than tech.
"Shop quoted a few thousand to repair the head gaskets." Yikes sounds like the shop is busy and doesn't want the job unless they at least get a new fishing boat out of the deal.
A:/ find another shop. The grinding noise is likely a flexplate bad spot with broken teeth. Not a big parts expense but labor intensive. Gotta remove the trans and TC and going by what they charge for shop time...find another shop.
You can easily inspect the teeth by just removing the trans inspection cover and rotating the flexplate with a big screwdriver etc. Might just be a trashed starter bendix drive/gear or combo of both?
If you can find a "reasonable priced" shop that doesn't like fishing, a blown head gasket isn't yet a call for a new motor.
Old 05-18-2019, 06:33 PM
Any links to good tutorials or info on the HG project?
Old 05-18-2019, 06:35 PM
It's been hell just to find a shop in Bozeman that would look at the Jeep. Other one we brought it to first just flat out lied about the trucks issues, and when I called them out, they were jerks. It was a terrible experience.
I wish there were more shop options in Bozeman or that I knew a Jeep maniac in Bozeman.
Old 05-19-2019, 02:14 AM
Try and find a good mechanic that does work on the side for cash, head gaskets are not that hard to do, just takes some tools and time. Look for a jeep club for recommendations.
Old 05-19-2019, 09:59 AM
oljeep.com has service manuals.
It's all in there...any year manual will work for head gaskets.
+1
I have found good people stranded on roadtrips etc., just by calling around & asking @ parts stores. The mobile guys usually are good and much cheaper than shops in small towns that know they have you by short hairs.
1994 Caprice wagon
1985 J20 Project Restore/Build GrCherokeeL General FSJ Discussion 119 06-21-2014 08:42 PM
mc 2100 overflowing issue altrocker1 General FSJ Tech 9 03-01-2012 12:00 PM
Rhino conversion issue banjoguy General FSJ Tech 7 02-16-2011 06:45 AM
Door panel project joker7037 General FSJ Tech 5 04-22-2010 07:07 AM
Timing Chain Issue? npbsurfr General FSJ Tech 17 04-04-2005 04:15 AM
