Old 05-16-2019, 09:29 AM
61Hawk 61Hawk is offline
Air Cleaners - Original vs Open Element
One thing I've wondered about while watching some of the rebuild threads is why are people replacing the original air cleaner housing with the open style? The original with the flex tube is basically a cold air intake, whereas the open is sucking in engine compartment air, and my '89 GW has the hottest engine compartment of any vehicle I've ever owned.
Old 05-16-2019, 12:01 PM
Tripwire's Avatar
Tripwire Tripwire is offline
just to look uncluttered .....if you enjoy even lower MPG's and drivability issues with a carb - go ahead and get yourself one. there is a reason the engineers put it there in the first place, waggies are not exactly hot rods right?
steve
Abort? Retry? Ignore? >
Old 05-16-2019, 12:25 PM
360 AMC
I think people like the way they look and assume they flow more air. Keep in mind, carbs don't really care about intake air temp. They are going to meter the air the same.
It could be argued that a 2bbl carb does not flow enough air to really feel the limitation of the single snorkel, too. I think on a stock motor with a 4bbl and any motor with a 2bbl, the stock air filter is more than fine. I think for a mildly built motor, you may need to flow more air and other options should be looked at.
Old 05-16-2019, 12:38 PM
I think most folks go for the look rather than the function. I've run open air boxes on other V8's and never really noticed any plus or minuses but it does sound cooler when the secondaries kick in. For most I think it's just a cheap/easy way to hang more chrome.
Old 05-16-2019, 03:29 PM
PlasticBoob's Avatar
All Makes Combined
Hawk, you nailed it. They're garbage down here in Southern California 90% of the year, or anywhere else where it gets hot for that matter. I have the datalogs to prove it. Can't believe I ran one for so long!
Rob
Click for video
About my previous thread regarding stock air cleaners BillyWagoneer General FSJ Discussion 63 08-15-2012 12:43 PM
Cold air intake ld8 General FSJ Tech 24 06-26-2012 04:24 AM
"spectere" brand re-usable air cleaners, as good as K&N? Tripwire General FSJ Discussion 3 03-20-2011 01:51 AM
Open Air Cleaner noviwag General FSJ Tech 4 01-18-2003 09:20 AM
The Zone has air ducts! Chero77 General FSJ Tech 7 08-11-2001 05:24 AM
