Old 05-15-2019, 08:42 AM
SOLSAKS's Avatar
SOLSAKS SOLSAKS is offline
HOW TO remove knobs from dash
1976 j-10
how do you remove headlight switch
and
wiper switch
I broke left hand vent knob
need one of those, I guess whole assembly with wire cable comes together ?
help appreciated
dave in NC
Old 05-15-2019, 12:31 PM
Originally Posted by SOLSAKS
1976 j-10
and
wiper switch
help appreciated
dave in NC
IIRC! Headlight - reach behind the dash for a button on the switch body. Push and the knob comes off. Wiper - there is spring washer in the knob that grabs the knob shaft. push on that with a screwdriver and the knob comes off. Vent cable - likely a junkyard item.
Old 05-15-2019, 01:16 PM
SOLSAKS's Avatar
thanx tgreese
dave in NC
Old 05-16-2019, 08:53 PM
67GMC's Avatar
67GMC 67GMC is offline
I've got my headlight switch out at the moment. Easiest way is to have the instrument cluster out first. That's held by about 6 screws and you need to unscrew the speedo cable. Then you can reach the headlamp switch harness on the left side near where the heater controls are located.
As mentioned, there's a little button you have to hold in while pulling the knob and shaft all the way out. The shaft is triangular so you want the button to be on the flat side of the shaft. Then pull it out slow while holding the button down. It should slide out pretty easy unless you don't have it on the flat side.
If you really don't want to take the cluster off I suppose you could reach up through the tangle of wires and try to feel for the button and try to hold your fingers on it while pulling, but it's very frustrating doing it that way.
My Stable:
1987 Jeep Cherokee Laredo, 4.0L, 4X4, Auto
1984 Jeep Grand Wagoneer, 5.9L, 4x4, Auto (newest project)
2007 Pontiac G5, 2.2L, Auto
2006 Toyota Sienna, 3.3L, Auto
2013 Toyota Matrix, 1.8L, Auto
1967 GMC 910, 283V8, 4SPD (RIP)
Old 05-19-2019, 07:05 AM
SOLSAKS's Avatar
thanx 67GMC that helped too.
dave in NC
Old 05-21-2019, 07:19 PM
fsj454 fsj454 is offline
Long time member
extras
I have some that where not up to my standards. Are yours black with white logo or Silver with black logo center section only . Knobs are the same
1982 cherokee nt. 454. nv4500 .205. dana 60 f+r. twin stick.hydroboost.hydrolic clutch.rock ram.traction bar.warn 12000 winch.4 wheel disc.flip kit.soa.high steer.cross over steer.4.56 detroit locker.35 spline rear alloy axles. 37s .1990 grand wagoneer aka trusty rusty
Old 05-23-2019, 01:21 PM
SOLSAKS's Avatar
cave man
thanx
I need one of the vent cable assemblies
the left one,.....it is shorter
my knob is fine and screws off
so if I can get a left side vent pull
that has a good clip
( the clip that holds them in the rectangular dash hole )
I will be happy
my knobs are black with silver symbols
thanx
dave in nc
Dash Pad repair HAARubicon FSJ-PRIS 6 08-05-2016 04:27 PM
Radio died :( How do you safely remove the dash bezel on an 89? Corellian Corvette General FSJ Tech 7 05-13-2015 04:40 AM
Pics of dash without dash pad? toyjeep General FSJ Tech 8 09-28-2009 01:27 PM
Any reason to remove Dash pad?? Dan Stewart General FSJ Discussion 7 09-24-2009 12:03 PM
