Old 05-14-2019, 07:24 PM
miamitj miamitj is offline
Need help ID'ing my distributor...
I have a '76 Cherokee that has an AMC 360 from supposedly an 80 Cherokee in it. I'm told the distributor is the original.
I'm trying to get a new rotor/cap as it needs it but none of the numbers that supposedly fit it, are correct. Seems like it's supposed to have a female cap but has a male cap.
Thoughts?
Old 05-14-2019, 07:37 PM
Looks like a stock 76/77 Prestolight(sp?).
Old 05-14-2019, 07:42 PM
I came up on that one while searching but I found none that looks like it.
Old 05-15-2019, 10:19 AM
Plastic vacuum advance canister is Prestolite. No doubt.
Resize your pictures to ca 800x600 and we can see it better.
Old 05-15-2019, 10:23 AM
I gave up finding a cap and just ordered a new hei distributor. It probably could have used a new one.
Old 05-15-2019, 12:38 PM
360 AMC
Make sure you swap the drive gear (do not use the one that comes on your new HEI, use the one on your Prestolite) or you will be pulling your timing cover in a couple thousand miles.
Old 05-15-2019, 01:09 PM
Ty will do!
Replacing stock distributor with HEI distributor xuno_gil General FSJ Tech 7 07-07-2011 10:38 PM
motorcraft distributor tuning. eliminating ping. several pics. Ristow Engine 18 04-02-2008 02:02 PM
Installation procedure for OEM dizzy Sgt Rock General FSJ Tech 25 09-09-2006 06:45 PM
