Old 05-13-2019, 02:43 PM
FlashGordon's Avatar
FlashGordon FlashGordon is offline
700R4 vs 4L60e questions
For cruising with lower RPM at 60 mph highway speed I want to replace the stock TF727 with a 700R4 or with a 4L60e (not for efficiency just more comfort -- now approx 2900 RPM and I supose with OD/4th gear I suppose 2200 RPM)).
No engine swap planned (so the Wagoneer keeps the very beneficial "historic car"-license plate in my country:
I read a lot here about the trans-differences but want to ask once more:
1) Gear-indicator-case and column shifter
Can I keep my stock honeybrown-coloured gear-indicator-case
or do I have to replace it because of the overdrive-extra-gear
when I go with the 700R4?
How does your solution look like?
2) My understanding is I don't have to change anything concerning
the gear-indicator-case /gear-indicator / shifter when I go with the
4L60e -- because everything is done electronically/automatically
(and more expensive because of the extra controller e.g.)
Correct?
3)
It seems that I need a Controller for the 4L60e
'Babywag' wrote here in the Forum, that GMs ECM 16197427 could be a cheap standalone controller solution.
Question:
Does anybody know if any part 16197427 will fit in this Situation (AMC 360 engine, any 4L60e Transmission from 1996 or so until 2008 or so)?
I ask because some seller say "... fits PROM code: BJYL..." or "... fits GM trucks 1995-1996..."
maybe this would only important when also swap an LS engine into the Jeep but not when keeping the old AMC engine
Correct?
4) Sometimes I read that it was necessary "to flash" the ECM/computer.
Question:
I suppose this might be only a situation when also doing an LS engine swap or so but will not be relevant when keeping the old AMC 360.
Correct?
Old 05-13-2019, 03:47 PM
RamJetFSJ RamJetFSJ is offline
The 4L60e still needs the same linkage to select gears as the 700R4. Just when and how it shifts between gears automatically is the part controlled electronically. Sorry, can't help you on the controller questions.
Ben Haines
1980 Wagoneer - GM Perf. Ram Jet 350 crate motor, built 700R4, NP208, 4" lift, 33x10.5 tires.
Old 05-13-2019, 06:53 PM
Mikel's Avatar
Mikel Mikel is offline
How about an AW4? Should be much easier to find in Europe.
1969 M715 6x6
1963 J300 Swivel frame
Old 05-13-2019, 06:55 PM
Cecil14's Avatar
Cecil14 Cecil14 is offline
Much easier to bolt in as well, as there's no adapters required. The controller is also standalone out of any early 90s XJ, with the addition of a few sensors (required for the 4L60e as well, I would guess).
Old 05-14-2019, 07:25 AM
AW4
What is an AW4?
Old 05-14-2019, 08:09 AM
... no adapters required?
It will direct bolt on the AMC 360 engine?
If so easy, shouldn‘t it be first Choice then?
Or is it weaker (not a problem for me I think, because I only cruise around)
And could I keep my NP229 without any adapter?
Or is there an good alternative?
Any universal or Jeep-specific controller needed?
Old 05-14-2019, 08:11 AM
Don't know all the years used but generally from 90's era XJ's My 90 and 96 XJ's had them. Good AT.
Old 05-14-2019, 08:15 AM
Yes, XJ parts are easier to find here in Europe
Thanks a lot for this advice
Old 05-14-2019, 10:48 AM
Cecil14's Avatar
The AW4 is a good solid medium duty auto. The same foundation was used in the turbocharged Supras of the same era (A340 maybe?) and held up very well.
I believe the AW4 was used through pretty much all of the 1990s. You should be able to keep the NP229, as they will both be 23 spline, but you will need to measure the stick out length on the transmission. I do recall if it stayed the same or not. You could also just grab the NP242 out of the same XJ and run that. Those can run in part time and full time modes, and will guaranteed bolt up.
I am also not positive which flexplate you will need. The 4.0L plate should bolt up, but it will not be balanced correctly for the 360. You can likely take your existing plate and the 4.0L to a good machinist and have them match balanced, so the 4.0L plate will work on your 360. Novak or Advance Adapters may make a 360 specific AW4 flexplate as well, not sure.
The only piece of caution I can think of is to watch out for the early transmissions (~'87-'90 or so), they may have used a 21 spline output shaft which you will not want.
Old 05-14-2019, 11:19 AM
Mikel's Avatar
If you search, you will find many AW4 swap threads on this site.
1969 M715 6x6
Old 05-14-2019, 12:36 PM
AW4
Didn‘t know that before so I never looked for this solution.
700r4 install questions 86grandwagoneer General FSJ Discussion 6 01-15-2015 04:28 PM
700R4 swap questions Greenfish General FSJ Tech 20 10-07-2011 09:00 PM
Gen III + 4L80E or 4L60E or 700R4 ???? ChileWaggy General FSJ Tech 28 12-20-2007 06:48 AM
A Couple of 700R4 Swap Questions Grantshire General FSJ Tech 0 12-05-2006 03:48 PM
Registered Numbers So Far 2nd Day East Coast FSJ Invasion 50 06-02-2005 01:00 PM
