  #61
Old 03-09-2005, 03:34 PM
scotty's Avatar
scotty scotty is offline
Originally posted by sputterinfuel86:
IIf you get a jeep turbo 400, which is just a gm tranny, and the quadratrac that came with it, you wouldn't have to worry about adapters save for the motor mounts. Right??
well,sorta
the th400 used behind amc v8s was made for amc and had a different bolt pattern than that used by the 6.2 and the small/bigblock chebby. in order to run a QT behind a 6.2/6.5(or a cehvy gas engine,for that matter) youll need find a chevy pattern th400 and swap the QT tailshaft and adapter into it [img]smile.gif[/img]
scotty
85 grand wagoneer
258/t18/d20/10 bolt/14 bolt
38" TSL SXs
chopped,bobbed and caged
Old 03-10-2005, 02:37 AM
sputterinfuel86 sputterinfuel86 is offline
'sheepish grin' ahhh...now i got it...thanks for the info
RIP-1986 Grand Wagoneer- \"The Shaggin\' Ski Wagon\"
Old 08-04-2006, 12:24 AM
Jodaddy Jodaddy is offline
What about the input shaft on a t18? Need lengthened after the 1/4 inch adapter plate? What about the whole clutch setup mechanical or hydraulic?
I have a 1987 6.2 hopefully going into a 78 cherokee. Which bell housing should I look for? clutch fork, release bearing, pilot bushing, etc?
Do I use the GM radiator or is it way too big? What is this oil cooler?and how do I retrofit it to the chero?
I hope you guys are still out there.
Thanks in advance
Joe
Old 08-04-2006, 11:10 AM
disregard my post. It seems that the 6.2 may not be repairable.
thanks
Joe
Old 08-04-2006, 01:06 PM
jlchilcot's Avatar
jlchilcot jlchilcot is offline
thanks
Joe
Id like to see an anwer to his post. Im in the planning stages to put a 6.2 in my J-20. I am also wondering about the extra 1/4 inch that the spacer will add.
75 J-20 360 T-18
77 Cherokee Chief 401 QT
80 CJ-7
2000 Ford Explorer Eddie Bauer 5.0
2000 Ford F-250 Powerstroke
See my Jeeps here
http://picasaweb.google.com/jchilcot
Old 08-04-2006, 01:28 PM
rustywagoneers_com's Avatar
rustywagoneers_com rustywagoneers_com is offline
most i hav eseen use an 'odd' pilot bearing (longer by the thickness of the spacer). and then they just let the clutch disc ride on a slightly different part of the splines.
peace
Dave
There is no way to rule innocent men.
The only power government has is the power to crack down on criminals.
Well, when there aren't enough criminals, one makes them.
One declares so many things to be a crime that it becomes impossible for men to live without breaking laws.
