Old 10-27-2017, 07:04 PM
babywag babywag is online now
GM standalone cruise control swap
Anybody done it yet?
I have a unit from the wreckmaster I bought for punishment, er I mean parts.
You know the one, used on GM cars/trucks 80s & 90s.
I am guessing it will be an easy swap.
Especially since I have TBI already, the column stalk is GM, etc.
Be nice to lose the stupid vacuum crap archaic setup!
1994 Caprice wagon
Old 10-27-2017, 10:04 PM
SJTD SJTD is offline
No vacuum??? Maybe work on a Diesel?
Got pics?
Sic friatur crustulum
Old 10-28-2017, 11:41 AM
kansasboy001's Avatar
kansasboy001 kansasboy001 is offline
I'd be interested as well if the column switch was cruise only. Would be perfect for pre 1986 jeeps
Old 10-28-2017, 12:33 PM
column switch on 86-91 is turn, headlights(hi/low), wipers, and cruise.
earlier just cruise stalks could work? I'd have to see one...
1994 Caprice wagon
Old 10-29-2017, 06:12 AM
bufurd's Avatar
bufurd bufurd is offline
The Dakota Digital unit is so easy, clean and works so well, I'll never have a vehicle without cruise control again.
Current fleet
07 JK Wife bought new...
Old 04-20-2019, 03:40 PM
Made some progress on this recently.
Got a VSS buffer from boneyard and wired it up.
Rounded up donor stuff from my stash of junk.
Here is where it will live.
Still need to go grab female pigtail from junkyard for column cruise switch.
Stay tuned for more.
1994 Caprice wagon
Old 04-20-2019, 06:22 PM
67GMC's Avatar
67GMC 67GMC is offline
You'll also may need a brake switch to cancel the cruise if you don't have one. I think it has to be a separate switch from the brake lights. I can't recall if my '84 has one but I'm pretty sure my '87XJ had two brake switches.
Good luck. I have three vehicles with non-working cruise. All my GM stuff worked forever but for some reason, Jeep and VW can't seem to keep their cruise control working.
Cruise is a must for me too. My Toyota has Radar Cruise control and it's really slick. Slows down automatically if you come up behind someone going slower than you.
My Stable:
1987 Jeep Cherokee Laredo, 4.0L, 4X4, Auto
1984 Jeep Grand Wagoneer, 5.9L, 4x4, Auto (newest project)
2007 Pontiac G5, 2.2L, Auto
2006 Toyota Sienna, 3.3L, Auto
2013 Toyota Matrix, 1.8L, Auto
1967 GMC 910, 283V8, 4SPD (RIP)
Old 04-20-2019, 07:21 PM
Brake switch is in the pic. White dude w/ 2 wires.
1994 Caprice wagon
Old 04-22-2019, 12:32 PM
Watching.
I bought an early GM cruise stalk for my 79 and it was exactly the same as the stock "Jeep" one I removed. Since we have GM columns, I bet the wiring colors and connectors will be the same between that module and the AMC one.
https://www.thecruisecontrolstore.co...ontrol-switch/
The wiring for the switch is also the same as the Dakota Digital CC module. I am hoping all that means the GM will bolt in with minimal wiring changes.
Did that module mount up use existing holes in the fender well or did you drill new ones?
Old 04-22-2019, 08:36 PM
Even if wiring is different on switch easily figured out.
It's just 4 wires for column switch.
I had to order a new column dealio too...mine tested bad.
Figures...but only $13 shipped for brand new one.
I drilled 3 small new holes to mount the module.
Got extra brake switch installed and stopped there.
Still need go boneyard for that cruise switch wiring connector & donor for a cable bracket.
1994 Caprice wagon
Old 04-23-2019, 11:40 PM
So wasted 2hrs @ local yard today.
Not a single donor for stupid connector I wanted/needed.
Going to just cut off the goofy flat connector and use something else.
1994 Caprice wagon
Old 04-24-2019, 06:29 PM
67GMC's Avatar
Come on. It just seems like 2 wasted years LOL!
My Stable:
Old 04-24-2019, 10:08 PM
HA! no doubt...guess my phone sub-ed yrs for hrs?
Anywho wired it up, all electrical tested out as it should.
Then as usual an unexpected complication, the throttle connector for the cable is different.
Unit came from a roadmaster guess TBI is different. So I'll have to redneck engineer something to connect the cable.
Was hoping to road test it tonight
1994 Caprice wagon
Old 04-24-2019, 10:45 PM
For something like this, would you need TBI? Or does it just need the right pulse generator? My CC worked for about 7 minutes and might want to get something with more available parts and not running on vacuum.
1984 GW
360
Comp 260H
Magnum Roller Rockers
Wiseco -21cc Forged Pistons
Performer Intake
Holley SA 670
MSD 8523
Dakota Digital custom cluster
Serehill headlamp harness
NWMP aux tank
1987 GW deceased
...but the parts live on
Old 04-25-2019, 07:31 AM
Absolutely not, you would need a gm vss 4 out buffer like pictured.
TBI cars used them.
It takes the Jeep 8k vss signal and divides it to a 4k signal that the cruise module uses. It's a stand-alone system.
Need from donor...
Cruise module, wiring, brake pedal(lower) switch, vss buffer.
Brake switch is important it is hot until press pedal then open. Reverse of brake light switch.
All pictured above.
1994 Caprice wagon
Old 04-25-2019, 07:53 AM
Wiring diagram cruise module
Here is a 96 wiring diagram, pretty basic install.
1994 Caprice wagon
Old 04-25-2019, 08:35 AM
8man's Avatar
8man 8man is offline
Nice post Tony. Very helpful.
Old 05-05-2019, 06:56 PM
Messed around with cable/throttle hookup.
Used a little arm(modified) from LT1 roadmaster TB.
Seems since this is TBI a TBI donor would have been a better choice.
But using what I already had...
Anyway here is my solution for connection on TB.
Now I just need to fab up a bracket for cable.
Unfortunately I also need to redo my fuel lines. The cruise cable needed to be in same space as fuel supply line.
Kinda annoyed but oh well.
1994 Caprice wagon
Old 05-07-2019, 01:33 PM
Got the bracket figured out. Just need to redo fuel lines and should be good?
1994 Caprice wagon
Old 05-10-2019, 03:04 PM
Success!
Got my new fuel lines bent up & installed = road test.
100% functional just like a factory install.
So for anyone interested in losing the crap vacuum setup or do not have cruise this is a decent cheap option.
1994 Caprice wagon
Dakota Digital Cruise control wiring questions. mdcptman General FSJ Tech 3 06-26-2016 04:04 PM
I want a factory cruise control in a rig that didn't come with it. Geminiroq General FSJ Tech 10 11-19-2009 05:37 PM
Cruise control wire Frzad General FSJ Tech 3 03-02-2009 12:06 AM
Cruise control on a 68 wag???? 380tom General FSJ Discussion 1 10-02-2008 01:04 AM
Cruise Control Adjustment JohnIL General FSJ Tech 1 02-13-2008 11:56 AM
