  #61
Old 02-28-2013, 08:58 AM
ProTouring442's Avatar
It may very be an illusion, but it looks to me as though the passenger side of the radiator is hitting the frame. If so, vibration will eat a whole in it very quickly. If not, please disregard this message!
Cool swap!
Old 02-28-2013, 09:01 AM
ross80truck's Avatar
ross80truck ross80truck is offline
I worked last night on designing my engine mounts. I have decided to go with more of an engine mount/crossmember. I set the motor in place and then took all my measurement. Then I laid it out on a piece of plywood and cut out a template. It took several different revisions to get it just how I like it, but this is my final design. There will be two of these. One in front and one in rear of the engine mounts. I am going to try to get them cut out of steel today and cleaned up and then tacked in place enough to hold the motor. Once I pull the motor back out, I will final weld everything up. I am also going to connect the two plates with some steal strap to make it more rigid. With this cradle and the heavy front bumper I am going to mount and brace back to the frame, I think the front end will be plenty stiff. I will just have to worry now about boxing in the back half of the frame.
Template test fit
Wood template
Life Priorities:
1. God
2. Wife
3. Children ( Lane )
4. Work
5. Wagoneer
Man it is hard to keep them in the right order!
Old 02-28-2013, 09:04 AM
Cool swap!
You are not wrong. In the pictures the radiator is sitting on the frame. I have it mounted loosely right now using the slots on the side of the radiator. So, it is sitting in its final location front to back, but when I final install it, there will be at least a 1" gap between the frame and the bottom of the radiator. Good eye!
Life Priorities:
1. God
2. Wife
4. Work
5. Wagoneer
Old 03-01-2013, 08:00 AM
Resbum's Avatar
Resbum Resbum is offline
That will be one beefy engine support. Are you going to have to raise the engine out of the support to move it forward or back, if you ever have to pull it? I don't think I quite understand the final product.
Originally Posted by Resbum
"What year is my truck?... Which part?" Build thread- http://www.fsjnetwork.com/forum/view...p=18290#p18290
Old 03-01-2013, 09:16 AM
It will work just like any engine mount, except that the two mounts will be tied together across the bottom of the motor. This will stiffen the frame in the front. It is very similar to how Eugene 1 mounted his motor in his Cherokee in post #65 of his build thread. We are just going about it differently.
http://i216.photobucket.com/albums/c...1330930188.jpg
Life Priorities:
1. God
2. Wife
4. Work
5. Wagoneer
Old 03-01-2013, 10:09 AM
Resbum's Avatar
Thanks. I got it now. Nice.
Old 03-07-2013, 11:51 AM
Finally officially got the motor mounted. I am really happy with how how it turned out and engine placement. I could not believe how much the springs collapsed when I set the total wight of the motor on them. The springs compressed a total of 6" with the motor weight on them. The wagoneer looks pretty goofy from the side right now. I have already been talking to Off Road Design about a set of springs for the front. They are not listed on the website, but they make a custom set of springs for the 80's model Chevy trucks to hold the weight of a Cummins plus give good ride quality and flex. They said a total of 11" of flex. Nice!
In this picture you can see how the engine mount runs completely under the motor to the other side of frame. This is to help stiffen the frame. I will take a piece of 4" strap and weld between the engine mounts from frame to frame to tie the two together.
Here you can see how the engine mount runs completely under the motor. As of now there is only 1" between my highsteer drag link and the oil pan. This will change when I mount new springs.
Notice how flat these springs are with the motor weight on them.
That is a lot of rake from front to rear. Not the look I was going for, but it can be fixed.
Life Priorities:
1. God
2. Wife
4. Work
5. Wagoneer
Old 03-07-2013, 02:50 PM
jMedia's Avatar
jMedia jMedia is offline
Looking great! Just a bit of sag.. Are those the stock wag springs up front tho?
Also, from a few posts back, why did you switch to the J20 steering box?
Keep it up!
Joshua
Constantly changing, never done
Old 03-07-2013, 03:19 PM
Keep it up!
Yes, they are stock wagoneer springs up front right now. I am most likely going to go with some custom springs from Off Road Design and also do a shackle reversal at the same time.
I switched to the J20 box because it is stronger than the stock waggy steering box and it bolts right in the same location. From what I understand the pistons are bigger in the J20 pump allowing for easier steering with bigger tires. I figured my tires are not going to be that big, but with the 6BT setting on top of them I could use all the extra help I can get.
Life Priorities:
1. God
2. Wife
4. Work
5. Wagoneer
Old 03-08-2013, 08:53 AM
Resbum's Avatar
Very Nice, Ross!!!
Old 03-21-2013, 09:21 PM
Bjtgtr's Avatar
Bjtgtr Bjtgtr is offline
Looking great!
-BJ-
1989 Grand Wagoneer FOR SALE. PM me for details
D60f, D70r, 360/727/300 twin sticked, 37"s, 4w discs, 64" rear springs, RSF, SOA, blah, blah, blah
2001 F-250 CC SB 4x4 7.3L Powerstroke DD
Old 03-30-2013, 11:28 AM
I like so many others here am moving my build thread over to FSJNETWORK.com. Please come over and follow the build there. It was fun while it lasted.
Life Priorities:
1. God
2. Wife
4. Work
5. Wagoneer
Old 07-25-2014, 09:50 AM
Jays jeep's Avatar
Jays jeep Jays jeep is offline
Noob!
what ever happened with this build? is it still under way?
1979 Jeep Cherokee S (38,000 original miles)
1985 Jeep J-10
1986 Jeep CJ7
1985 Jeep CJ8
1969 Jeep Commando
1986 Grand Wagoneer
1978 Jeep CJ5 Silver Anniversary
1949 Willys 2A race Jeep
1983 J-10 Stepside
Yes they all run and drive (well, most of the time)
And for the right price they are all for sale so I can buy others.
Old 07-25-2014, 11:48 AM
Achilles's Avatar
Achilles Achilles is offline
I think he moved the build thread over to the other forum.
YouTube: http://www.youtube.com/channel/UCmcfvYSDdeFJ-NHY1MA_9Iw
Will a dodge D60 front axle bolt right into an FSJ? Karl Streich General FSJ Tech 6 08-06-2005 01:10 AM
NP205 clocking, (long post and several pics) JeepsAndGuns Off-Road FSJ Tech 8 06-07-2005 11:04 AM
help!!!! ford d60 banjo bolt on front caliper jeepzilla47 General FSJ Tech 6 04-02-2005 09:21 AM
83 Wagoneer - replacing front & rear leaf springs Wage General FSJ Tech 3 03-11-2005 02:46 AM
wagoneer front spring interchangability RodeoRob General FSJ Tech 8 04-26-2002 06:36 AM
