I have an 89 Grand Wagoneer with 94k miles. I put a 4" lift on and 31" tires. I am not planning on going to bigger tires now or in the future. Axles are Dana 44 front and rear, both open diffs and geared 3.31. Howell TBI and HEI distributor (base timing is set to 19 degrees BTC because of altitude). Engine is stock aside from TBI and HEI, no changes to the cams, etc. Automatic tranny (3 speed unlocked) and the kickdown lever is correctly adjusted. I just replaced my charcoal canister and idle is better now, still have a mild stumble and mild hesitation. I have not done a compression check. Engine passes emissions and does not blow smoke.
I am at 5300 foot altitude (20% less air density, so 20% less oxygen and 20% less power compared to sea level).
Acceleration getting on the highway from the entrance ramp is not that fast. I worry about getting rear ended as I get up to speed. Many of the drivers here are not very polite and don't make way for slower vehicles. I don't plan to do alot of off road with this Jeep, I have lots of XJ's for that. I am considering re-gearing for better acceleration and putting a limited slip in the rear for driving on ice. I have a spare limited slip carrier from a 1988 XJ small Cherokee rear Dana 44 with 30 spline axle shafts. That carrier is good up to 3.73 gearing if my research is correct. It came with 3.54 stock XJ gearing.
I have about 150 pounds of cargo in the rear, but no other extra weight (no after market bumpers or winch).
What gearing do you recommend? Gas mileage is poor anyway so that is not my main concern. I am driving around town and on the highway about 20 miles per day.
Will the limited slip carrier from the XJ work in the G Wag rear Dana 44? If I go above 3.73 numerical gears, then can I use a thick cut ring gear with the limited slip carrier from the XJ?
How will my top speed be affected by gear change? I normally don't drive over 75 or 80. I sometimes take the SJ up into the mountains which are at an even higher elevation and the highway is a very steep grade.
Would 4.10 gears rev too high on the highway? Will 3.73 give enough acceleration, especially on paved mountain highway passes with 4 people in the Jeep?
Looking forward to hearing from people's experience, especially anyone in Colorado or at altitude elsewhere. Thanks in advance.
David
David
