Well I finally decided to upgrade to the Performer #3731 intake and #1406 carb. However, I'm not sure exactly what all additional parts I'll be needing for this. Perhaps someone else has been down this road before and can clarify this or let me know if I'm forgetting something.
Edelbrock parts:
8034 Throttle cable adapter
7213 intake gasketts (I've read some folks prefer using the original valley pan metal gasketts while other say you can't since this intake is aluminum.) I think the jury is still out on this one.
9300 Gasgacinch sealant for the intake
2732 Squarebore adapter (is this necessary or does it come with the carb)
J4006019 AMC grommet for the PCV
8134 Idle/AC solenoid (does the factory one not fit or can it still be used?)
1481 Throttle lever kit for accelerator and cruise controll (is this necessary or does the one on the new carb come with one, or can the one from the MC2150 be used instead?)
8134 Fuel line kit (the fuel inlet on the #1406 is on the side of the carb as opposed to the front and will need to be relocated. Is this the right kit to get?)
8092 Air cleaner spacer (Is this needed with the factory air cleaner and will the factory cleaner fit a #1406?)
9266 Squarebore carb to intake insulator (will this case the air cleaner to be too hight and not clear the hood?)
Edelbrock parts:
