Old 09-13-2019, 03:36 PM
CLL CLL is offline
J truck parking brake question
Hi All, Why does the parking brake hold great when facing downhill, but is pathetic when facing uphill? Something with the geometry of the turning drum and the shoes I guess. Is there a fix? I tried adjusting it up till it bit good, but then the brakes would drag and heat up while driving!
Thanks, Chris
Old 09-13-2019, 08:17 PM
Are the shoes on correct? Are the adjusters backwards? are the drums worn out? Are the shoes adjusted to fit the drums? Are your park brake cables worn/stretched out? Lots of question you need to check off.
parking brake switch damaya General FSJ Tech 6 09-18-2012 07:18 PM
Eldorado caliper / E brake question **Update** BarryL General FSJ Tech 3 03-06-2008 06:05 PM
Connecting Parking Brake w/ Lift Question 80wag General FSJ Tech 4 01-09-2007 10:11 AM
Rear parking brake cables for the J badaboom General FSJ Tech 2 12-09-2006 08:25 AM
Disc Brake Conversion/ Parking Brake option Merc69 Off-Road FSJ Tech 29 09-22-2004 01:58 PM
