Old 09-05-2019, 03:48 PM
mgmann mgmann is offline
Rear spring bracket replacement
Recently took my 88GW in for a paint job, new vinyl and anything else that might need fixing. Although the outfit is almost completely rust free I found that the frame was badly rusted where the fuel tank skid plate attaches - typical for this rig I am told. I got one of the kits from Team Grand Wagoneer and my body guy says he can install it.
After seeing this I did a little more digging to see if there are any other rust issues I haven’t seen, and found that the driver’s-side rear spring bracket is badly rusted. I always tried to keep the drain holes clear, but it still clogged up with mud. The body guy doesn’t seem to think that it’s a big deal, but I’d still like to find a permanent solution.
I’m sure other guys have had this issue and I’d like to know what they did to resolve it? Is it possible to get a new bracket that can be welded on and if so where can I get one?
Thanks………..
Old 09-06-2019, 01:46 PM
Cecil14's Avatar
Cecil14 Cecil14 is offline
Mid 90s Ford Ranger rear spring hangers should fit, that's what I've been running for a while now. Replacement brackets are built to be riveted or bolted to the frame, but you could easily weld them on. They are a much better design than the boxes on our rigs, and will not clog up and rust out like ours.
Something like this should work:
https://www.stengelbros.net/338-1950...er_p_1953.html
I found some other ones that were a better and stronger design, but I can't find the link right now. If I come across it, I'll post it up.
You don't need to spend much, though. Any mid-90s Ranger rear spring hangers should work.
Old 09-16-2019, 09:31 PM
Cecil14's Avatar
Here is my install from a while back:
https://www.fsjnetwork.com/forum/vie...155373#p155373
Old 11-10-2019, 03:31 AM
Mars's Avatar
Mars Mars is offline
Wow that's awesome, I have one that just graduated from the "It's okay" to " I should start looking for a new one of those" categories.
What shackle would you suggest with that hangar setup?
Wannabe Fabricator
Grumpy on a good day.
Old 11-11-2019, 08:21 PM
Rusty76 Rusty76 is offline
Hi I recently replaced the rear spring brackets with the ford ranger parts.
I also attempted a shackle flip. It did not work out like I was hoping. Old stock springs are pretty much flat. Think I needed to move hanger even closer to front. I'm hoping that new springs will help but I'm not sure. Should have just did it the normal way
Anyway the hanger are bolt on and that part of the job was pretty easy.
I also ordered Ranger shackle but decided to use new Wagoneer stock one instead.
Hope this helps. Sorry for the dark pictures
IMG_5397 by , on FlickrIMG_9980 by , on Flickr
IMG_4176 by , on Flickr
Old 11-14-2019, 09:54 PM
Mars's Avatar
very cool posting the pics man thank you!
Wannabe Fabricator
Replacement rear spring hangers Cecil14 General FSJ Tech 2 02-06-2018 06:17 PM
Rough country rear spring overload leaf deadironrat General FSJ Tech 17 02-16-2009 09:39 PM
Building a rear leaf spring pack. trail mule Off-Road FSJ Tech 3 01-20-2009 12:24 PM
Alright Alright, I'll turn my rear spring wedges around. 89grand General FSJ Tech 35 09-02-2004 10:27 AM
