Old 09-12-2019, 03:26 PM
Originally Posted by babywag
What is your FP set @
Did you change the injector flow rate in .bin to match your injectors @ that FP?
If the value isn't correct the pcm calculations for fuel will be wrong.
It appears to be rich, but without seeing the logs or the fuel trims just a guess.
You might want to look @ INT & BLM in monitor to see what's occurring ~backfiring?
Before significant changes to fuel map as I suggested a couple times already force it OL and see how it runs.
Fuel pressure is at 12psi.
Yep, bin is set to same flow as injectors.
I look at BLM and INT while I am driving and did look at them in the history graphs. They are better for the 401 bin than the 454 bin but I don
I look at BLM and INT while I am driving and did look at them in the history graphs. They are better for the 401 bin than the 454 bin but I do not really understand it or what is “good” or “off” so I don’t pay a lot of attention to it yet.
Yep, gonna drive with O2 sensor unhooked and log. First I am going to check my dizzy phasing, then take for a drive with O2 unhook
Old 09-12-2019, 04:21 PM
In CL BLM & INT should be ~128
Anything under 128 the pcm is pulling fuel over 128 adding fuel.
Cannot tune VE tables without them.
Need good data to get in ballpark.
Old 09-16-2019, 12:58 PM
Ok, that's what I assumed but wasn't sure. I did use them for the VE tables but plugged them into the excel spread sheet and it did the computations.
IT'S "FIXED"!!!! It was distributor phasing!
Sorry the pictures are so bad. It's pretty hard to get these pictures. I basically video'ed them and screen captured it.
Here it is with the timing plug pulled (timing at 0 degrees):
Here it is at idle with the timing plug in (so timing is at 20 degrees advanced). With the spark that far over, I don't know how it even ran at max timing!! I should have had LOTS of mis fires and back backfires.
I pulled my dizzy, brought it into the garage and unscrewed the pickup lockdown screw. I marked the location of the #1 stud on my cap adapter and rotated it so when the star wheel and magnetic pickup were centered for #1, the rotor tip was just passed the stud. This would mean that at 0 degrees, the spark should be on the trailing edge of the rotor. This moved the pickup about 10 degrees so I screwed it back down.
Here it is after moving the pickup. This is idle at 0 degrees timing:
And the best picture! At 20 degrees of timing, it's pretty much centered.
I took it for a spin. Did my normal route, with 401 tune. I did not data log because I didn't feel like grabbing my laptop and booting it. Got up to 70, eased of the throttle.... NO BACKFIRE!!!!! WOOOOoo HOOOO!!! I got off the freeway, headed down run 3 and cruised at 50, NO BACKFIRE!!!! I was feeling pretty triumphant as I turned at the gas station heading toward home.... then it stalled. I cranked it over, no start. Are you 'ing kidding me?!?!?!?! Fuel pump died. At least it doesn't backfire anymore.
Old 09-16-2019, 02:15 PM
posulli88's Avatar
posulli88 posulli88 is offline
Thats Awesome! Congrats on figuring it out, nothing better!
Old 09-16-2019, 03:16 PM
Mikel's Avatar
Mikel Mikel is offline
1969 M715 6x6
1963 J300 Swivel frame
Old 09-16-2019, 09:27 PM
Full Size Jeeper's Avatar
Glad you have it figured out
1978 Wagoneer
Mods:
Old 09-17-2019, 05:06 AM
chubbinius's Avatar
chubbinius chubbinius is online now
Those are two of the greatest words to hear...bet you're smiling from ear to ear...hopefully the fuel pump will be a quick swap.
1970 1414X Wagoneer "The Pig"
-Dauntless 350 V8
-D27 front/D44 rear
2006 XK (65th Ann Edition)-DD
Old 09-18-2019, 08:27 AM
YASSSSS - victory! Congrats!
1984 GW
360
Comp 260H
Magnum Roller Rockers
Wiseco -21cc Forged Pistons
Performer Intake
Holley SA 670
MSD 8523
Dakota Digital custom cluster
Serehill headlamp harness
NWMP aux tank
1987 GW deceased
...but the parts live on
Old 09-21-2019, 07:44 PM
PlasticBoob's Avatar
All Makes Combined
Great job! Now go crank trigger with LS coils.
Rob
Click for video
Old 09-22-2019, 11:24 AM
Hahahaha!!! Funny you mention that! Probesport did a thread on it and I almost bit on doing it during my rebuild but decided I was getting side tracked. I would love to go distributor-less but I have so many other fishes to fry before I do.
Backfiring thru Carb - long saga NO6YHY General FSJ Tech 26 08-06-2013 05:47 PM
Exhaust backfiring question jaxfljeep General FSJ Tech 5 07-27-2012 11:31 AM
Backfiring thru the carb grand_wag_85 General FSJ Tech 17 06-04-2007 06:08 AM
Random Backfiring brielly General FSJ Tech 1 07-17-2006 08:18 PM
BACKFIRING / EXHAUST ISSUES FSJ-Earl General FSJ Tech 17 05-22-2006 03:52 AM
