Old 08-27-2019, 08:04 PM
brentwood brentwood is offline
Steering wheel fitment
I found a nice steering wheel on eBay listed for a 84-96 Wrangler, Cherokee. Not sure if it would work for me...
What years and models of stock Jeep steering wheels would fit for my 72 jtruck?
1982 Wagoneer w/258, Rusty's 4in spring lift, motorcraft 2100
Old 08-27-2019, 10:10 PM
Cecil14's Avatar
Cecil14 Cecil14 is offline
I've got a '94 XJ steering column/wheel in my garage next to my '83 column/wheel right now. I can take a look in the next day or two and let you know if those two swap, if no one else replies. Unfortunately, I do not know if the '72 column is the same as the later columns or not.
Old 08-28-2019, 03:25 PM
That would be great thanks
Old 09-08-2019, 02:27 PM
Cecil14's Avatar
Sorry it took so long, but I finally got some time to play with the steering columns. I had no trouble taking the wheel from my '83 and putting it on the XJ column.
Don't know if that will help you much or not.
Steering woes continue, getting annoyed... DanHS General FSJ Tech 11 06-22-2011 08:46 PM
Dead Spot in Steering Wheel heep2jeep General FSJ Tech 3 07-21-2008 01:59 PM
82 Steering wheel on 88 Steering column? ohioj20 General FSJ Tech 3 07-20-2007 04:04 PM
Steering Wheel Conversion in Wag Jeepeta General FSJ Tech 5 11-22-2004 07:44 AM
steering wheel worn and torn? -READ THIS- youngjeeper General FSJ Tech 7 06-09-2004 12:08 PM
