Go Back   International Full Size Jeep Association > Classifieds > "Look Here" for Parts, Vehicles and Vendors > Homegrown Vendors: (Members who produce FSJ related items)
Closed Thread
Old 12-28-2011, 12:09 PM
serehill serehill is offline
Gone,Never Forgotten.
Headlight relay harness 400+ sold so far the best built harness available FACT
Over 400+ soldOver 400 sold
After a few conversations it has come to my attention a need for a wiring upgrade to the headlight systems to Halogen or quad lamps. I have ordered some parts & will be building these.
The reason I am venturing into this is because in the last few months I have seen these links for headlight wiring upgrades & the are not all inclusive & do not relieve the entire system of load. They're simply are a bandaid on a bullet wound. Any mod that does not remove the dimmer switch from the load is not a cure. I saw one mod the other day that the author called simple that was anything but. It was clear it would have taken hours & you would have to have some pretty good knowledge of circuits & relay function.
Also the system is not reversible if something were to go wrong. Mine Is.
New system:
The system design does not require any modification cutting or removing of the existing system. The cost would be 55 bucks shipped to your door any where's in the United states. There are some available mods that may add a little price. They are optional.
The system is based off of the new HID type bypass & simply allows the old electrical system to become controllers of the system but not carry any of the headlight amperage load. The old system will simply control the new relays & the relays will manage all current.
Installation:
This system is installed by removing your headlights & installing a harness across the front inside the header panel & then connecting the harness. The positive & negative are simple connect to your battery & any ground connection. This mod also utilizes porcelain socket for the bulbs instead of bakelight. The harness will pick up power & run it straight to the headlamps.
It will be cheaper & simpler than the links which have you tracing & cutting up all kinds of old wiring.
Install would be:
Remove the headlights & unplug old wiring.
Install new harness by threading the left side controller & socket from the right headlight location to the left headlight socket.
Take the fused wires & run them through the header panel to the starter relay. Connect the fused wire to the solenoid battery side.
Connect the ground to any ground source. The process will be to use a self tapping screw & mount the provided lug to the header panel. Also there are already existing places there for other grounds for parking & side markers & headlights. You can mount the grounds to these places or create a new spot with a self tapping screw.
Go to the right side & connect the black wire from the socket to any ground as described above. Then plug the new supplied socket to the headlamp & re-assemble.
You can tape up the old socket but it will not be used on the right side.
The Left is a little different because you will have to mount the relay (easy)
Also on the left there is a male plug that simply plugs into the original headlight plug & tape together. (pictured later) Then connect the black ground wire to ground same as right side. Then connect the new (yellow) socket to the bulb.
Run the wire with the fuse on it to the solenoid & connect it to the battery side of the solenoid. Mount the fuse holder optional But recommended.
Mount the headlight back & your done.
The wiring will be marked right & left sockets.
I have ordered the parts to build another 30 of these. The first one built that was not for me was for a buddies cj & it worked perfectly. He was having problems with his dimmer & wiring burning up. This has fixed that issue. He had 4 Kc daylighter connected to his.
I'm simply gauging interest for this since all of the mods I've seen are complicated & really intrusive.
you should be able to do this in an hour. I would allow 2.
Why the harness.
1.Bypass old wiring with the heavy loads.
2. Provide a better wiring system to upgrade your lamps to halogen.
3. Improve the voltage to your light to make them brighter.
4. I saw one Forum member that says his caught on fire & burned his rig &
wiring pretty bad.
5. Low impact this can be unwired & put back to stock should someone
should want to. Really there is not impact to your existing system
6. No wiring mess under the hood or under dash. The only part you see will be the red/fuse & black wire by the battery.
Options:
This system could be easily modified to run a quad light system it you were to put headlight in the pie plate orifices. I would have to know that & modify the system.
2 spare relays 10.00 bucks
Again this is just a feeler to see if there is demand. I would have to get product to built if there is a positive need. This is not for profit but just to provide a solution. It would easily sell for a lot more. I may put some on ebay.
This system will work on all jeep applications. Actually it could work on any applications.
Please let me know your thoughts if there's no demand there is no demand. The guy I built the one for the CJ said I should check to see if there was a market or individual need.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
Old 12-28-2011, 12:37 PM
mathman's Avatar
mathman mathman is offline
I'd be in for two sets ('78 J-20, '79 Cherokee), one of them possibly for the quad light setup (depends on what I decide to do on the Cherokee).
David
'78 J-10; '78 J-20 8400GVW
'79 Cherokee
'50 Willys (not Willy's) 4WD Pickup
Old 12-28-2011, 12:43 PM
Tin Medic's Avatar
Tin Medic Tin Medic is offline
Loose (lug)Nut(s)
I'd be in for at least 1.
Sons Waggy - 89 GW 360/727/208, 30x9.5x15 Destination M/Ts, Warn Lock Out Hubs, Razor Grill
Tramp - 85 CJ-7 Renegade FI 258/T5/D300, D30 w/ARB Air Locker, AMC 20 w/Posi Unit, 33x12.5x15 Goodyear MT-R's, Hella E-Code lights, VIAIR OBA System, Warn 8000lb Winch
Old 12-28-2011, 12:56 PM
five16's Avatar
five16 five16 is offline
I'd be in for one with the quad set up for SURE!
You can teach what you know but you can only reproduce what you are.
It makes sense if you don't think about it.
Brad B.
Old 12-28-2011, 01:45 PM
OK
I'll order some more parts & get these going I'll build 10 they will take a little bit to get the parts in. I'll follow up with a notice there I expect to be able to have them comlete by 1-20 I'll need the particlars. This really would be the only way to run quads.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
Old 12-28-2011, 10:03 PM
Stupified's Avatar
Stupified Stupified is offline
That's a great idea for those intimidated by wiring. I just double relayed mine or I'd be in for a set. That kind of set up should work for all the older sealed beam jobs in all the American iron. Good luck to ya !
73 Wagoneer 360 400/20 D40/D30 3.31
285/70R17 DuraGrapplers
post flipped rear, rough country 6110 chevy front AAL
Camo green Zombie Response Vehicle
Old 12-29-2011, 10:02 AM
Thanks I ordered enough to make 10 sets.
good deal.
If you used one of the existing links for headlight mods going around ensure you didn't leave the dimmer in the load circuit. That's the headlight dimmer to be clear not the dash lights. Even on later models they can not carry current without failure. If you did the complete wiring & fuse block then you know it's a little complicated and has a tons of components that have to go somewhere. 90% of my mod is hidden & will be ideal for the restorer that did not want to expose the relays & cabling. This will easily work on any h4 system & deliver better power with porcelain sockets for the hot lamps. I have HIDs but most people don't like them so I created a way to improve the set up. The guy I built the CJ set for had a 4 bulb set up. That thing will light up the night. he burnt up 2 headlight swiches & one dimmer trying to run it on the original wiring. This wiring is optional to run all four lamps hi/lo or just run 2 hi /lo & 2 high only. All you would do is cut 2 wires on the harness to make this happen. I will probably set up a 6 volt system also. You never know.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
Old 12-30-2011, 10:39 PM
WXALL's Avatar
WXALL WXALL is offline
I'd be interested, also. Could you post pics of the installation?
Old 12-30-2011, 11:46 PM
Tigger4X's Avatar
Tigger4X Tigger4X is offline
Sounds advantageous. What years would this work for? My '70 and '74 J-trucks only have 37 amp alternators. Will these work on them? I hope so!
Curiosity ...
I have been trying to figure out how to splice the wiring from an 80's alternator into them so I'd have a 65 amp alternator that only costs $40 new from my local parts house VS the freakin' $85 for an alternator and external regulator. Do you know anything about alternator wiring? I'd be up for a "paint by numbers" tech write up to make it happen on my trucks. For sure the headlight upgrade would not be an issue then. TIA!
Originally Posted by will e
Old 12-31-2011, 12:46 AM
Actually it will work on any 2 head light systems.
And can be built to work a 4 light in any combination the only requiremnt is the H4 style socket. They will be a proffessional product heat shrinked etc.
I doesn even't have to be a jeep 2 or 4 light. Square, round, convereted,etc. It can also handle some cutsom interwiring such as connecting your fog light to high beams.
There's other combos.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
Old 12-31-2011, 10:39 AM
SNO*MAN's Avatar
SNO*MAN SNO*MAN is offline
I want one for my 89.
How does it work with the driving light configuration? My driving lights go off when the hi-beams are on, does this change at all?
1989 "KRONK"
Detroit front/rear 4.27 gears
Ramsey 9000 modified bronco winch bumper
Built 360/ 700r w/ 241c Lokar floor shifter
Hydro-boosted brakes
20" wheels w/ 35" Toyos
15" Welds w/35" Uncut mud boggers
Dual Ram Air /MSD TFI Ignition /Dakota Dash
www.fastfinishor.com
www.fastfinishor.blogspot.com
www.facebook.com/fastfinishor
Old 12-31-2011, 11:01 AM
well
It would take a little mod to make it do that (easy). Basically it would do that as it stands you would just need a pigtail to connect your driving lights to much like having a 4 headlight system just that 2 would be single beam. The drivers would be connected to low beam. Yes they could also be reversed & come on on high beam. I bought enough stuff to build 12 I will build 5 then custom the rest.
So what would happen is there would simply need to be a wire added of the low beam on each socket right left to go to the driving light. I have the relays & had to custom order some sockets It looks like I should be ready to build the 3 rd week of January. we've built one that ids doing exactly what you want on a CJ.
As soon as all parts are in I will pm you guys to let you know & let you decide what you want to do. I'm already building one 4 lamp system.
Also considering auto ressetting circuit breakers as opposed to fuses. Right now fuses are the thought.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
Old 12-31-2011, 12:33 PM
SNO*MAN's Avatar
I always thought the stock configuration was backwards. I prefer the driving lights on with the high beams myself. Since it is lifted, It appears that most people get blinded more by the driving lights and the low beams over the high beams alone. Adjustment wont fix that.
I need it to be easy to install though. An electrical issue burnt my last jeep to the ground before I got it fully insured. So electrical is a big concern of mine.
1989 "KRONK"
Old 12-31-2011, 12:36 PM
price is decent. sounds like a good idea.
i believe it's against most states law to have aux lights on with high beams. dumb. i have mine wired on with high beams,never been hassled about it.
Old 12-31-2011, 01:57 PM
dadd2009 dadd2009 is offline
I'd be interested.
1984 Grand Wagoneer
UGLY, with 360, 727 and NP229.
Mods: All aluminum radiator, HEI, CS144
Future Mods: Rebuild heads, cam, lifters, timing chain, aluminum intake, 4 barrel, SOA & 33's
Old 12-31-2011, 02:15 PM
SNO*MAN's Avatar
FYI for Oregon users
In regards to auxilary or fog lights in Oregon:
The way I read it, the factory auxilary driving lights are wired backwards - except that they can be turned off completely via a switch....so they are still legal.
http://www.oregon.gov/ODOT/TS/docs/V...fog_lights.pdf
According to Oregon law, fog and/or auxiliary lights must be used like the high beam headlight system of your car. They must be turned off within 500 feet of approaching an oncoming vehicle and 350 feet when following another vehicle. The color of fog and/or auxiliary lights is also regulated. Fog lights may be either white or amber (yellow). Rules prohibit other colors such as blue.
SO, for me I want mine wired so they can be on with the high beams.
1989 "KRONK"
Old 12-31-2011, 07:43 PM
It will be safe
The sytem is gong to come completely protected that's one of the parts I'm waiting on is a fuse housing. It will be protected by a 30 amp fuse that will be connected right at the battery as stated in the original discription it will be pretty elementary with full support. The circuit will be completely fuse protected from as close to the source as the fuse can be. It will use 30amp gm type fuses. The realys & housings will be american made. The relays will also have a plug in harnes & are a standard buy anywhere replacements to ensure they are servicable. I could solder them to the relays but that would make trouble shooting a PITA. As the first couple of people will see it is a well thought out protected servicable system. LOL now I wishing I had the parts.
These sytems are based of of the same system & controls GM is using in their trucks. I have no problem telling you I will have $41.00 just in unassembeld parts. Could I build it cheaper well NO!!!!
Reading about the laws I haven't found any that has restrictions with respect to beam connections. But it can easily be made to operate the beams in any combinaton. you can actually build the 4 headlight system with all 4 lamp having hi & lo beams
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
Old 01-01-2012, 07:09 PM
I may do some post
Once I built a couple of them I can do a mock up.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
Old 01-01-2012, 07:11 PM
Tigger they will work on all years
Curiosity ...
CJ Jeepsters FSJ Tons of other if it has the square or 7" round headlight this will work. It will work for standard Halogen Xenon & HID Lamps.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
Old 01-01-2012, 07:30 PM
All FSJ's CJ's Jeepsters.
Anything with a square or 7" round headlights all Chevies ford dodges.
Any lamp with an H4 /9003 type socket
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
Closed Thread
Poll- Interest in custom Safari Rack? Walt General FSJ Tech 22 01-06-2016 05:01 PM
Gauging Interest - Ignition control Dizzy's? Billygoat Fuel Injection 2 10-01-2011 06:03 AM
Gauging Interest 1986-1988 J-truck Fuel Sending Units TPICherokee General FSJ Discussion 26 12-04-2010 07:33 AM
Gauging Interest - EFI rawdave General FSJ Discussion 6 08-25-2008 05:43 AM
