Old 10-25-2010, 01:56 PM
wanderson wanderson is offline
Permenantly removing roof rack
I'm thinking of removing the stock roof rack on my '87 Wagoneer, but not sure how's the best way to plug up the roof holes. I saw on someone's personal website that they had used nylon plugs & clear silicon when they replaced their stock roof rack with an aftermarket rack. The roof is rough n' rusty with a thick coat of rust preventer so any plug/patch isn't gonna make the roof look any worse. Anyone else tried this?
Old 10-25-2010, 02:11 PM
p@55w0rd's Avatar
p@55w0rd p@55w0rd is offline
Plugs sound like a good temp fix... Can you share a link to the web site where you got the info?
Project: 1979 Wagoneer 360, Turbo 400, Q-Track, and Dana 44's
Lovingly refereed to as the "The Wagon"...
Daily Driver: 2008 Jeep Commander Rocky Mountain Edition 4.7L, Q-Trac II
http://i285.photobucket.com/albums/ll58/jeepxk/DSC08388.jpg
Old 10-25-2010, 03:06 PM
El_Diablo's Avatar
El_Diablo El_Diablo is offline
thats how my wag is currently done... its a common trick for removing spoilers amongst the import crowd and does work as a good temporary fix
Old 10-25-2010, 03:18 PM
rmorit01's Avatar
rmorit01 rmorit01 is offline
Mine is "de-racked" too -- I just went to the local hardware store and looked for the caps that have a large "outside" cap and a smaller piece that goes into the holes.
Used small nylon plugs for the roof rack strips and screw holes.
All applied with silicone sealant -
Bob
79 Cherokee S
Old 10-25-2010, 04:48 PM
krek's Avatar
krek krek is offline
Perpetually Perplexed
I had my holes welded up.
Old 10-25-2010, 06:55 PM
EBCIII's Avatar
EBCIII EBCIII is offline
My 77 Wag came that way. I plan on leaving it. IMHO I think it looks cleaner, Beale.
Old 10-25-2010, 07:27 PM
Bill Lawton's Avatar
Bill Lawton Bill Lawton is offline
Weld them up no leaks!!
_____________________________________________
Heaven begins where the pavement ends
1978 Cherokee Chief 401
TH400 QT w/LO D-44 3.54
www.cabinet123software.com
Old 10-25-2010, 07:40 PM
CutterN55's Avatar
I wanna pull mine off and weld it up too, but I'm kinda chicken. I go back and forth somedays liking it others I just can't stand it. I'll probably pull mine off, and take the real nice one (that is useless 9' in the air) off my Excursion and throw it on the Jeep in place of the stock one.
however I seal it up, I'm going to line the top with good textured bed liner that will hold up to a beating and to the elements and it will hide any imperfections caused by welding the holes up.
ROMANS 12:1-2
'89 GW deceased
Ford 4spd swap Np435/205
Old 10-26-2010, 06:49 AM
plugs
I guess I was kinda hoping I could find some kind of roof rack hole plug kit like the ones you can get for Volvo wagons. Here's the link to the website that used the nylon plugs/silicon:
http://www.casscomm.com/~rollingm/wagoneer/main.htm
I'm still toying with the idea of getting new wellplugs, or whatever you call those gizmos that go in the holes and expand when you tighten them up, and just removing the roof rack and reusing the torx screws with washers, assuming I could find some stainless washers big enough to cover the 1/2" hole that will work with the torx screws.
There was also an earlier thread that mentioned fiberglass patch, probably the better permemant solution but my headliner is in decent shape so I don't plan to pull it anytime soon.
Old 10-26-2010, 07:12 AM
well plugs
I stumbled across another forum discussing the same problem for a Nissan truck, someone posted this link to a parts warehouse website with a good selection of wellplugs:
http://www.mcmaster.com/#catalog/114/3214
never ordered from them before but they have a gi-normous selection of miscellaneous parts. Although their 1/2" wellplugs run about 8 or 9 bucks/10, and Team Grand Wagoneer has all 12 for $18. I may just order a new set from TGWagoneer and try the torx screw/washer fix. If I decide to put the rack back on, I'll at least have new plugs in the roof.
Old 10-26-2010, 11:52 AM
I'm not not much into plastic plugs. If'n were me I'd inject silicone (black) into the holes. If ya get sloppy and get too much in it smooth it out with an ice cube. Silicone won't stick to ice like it does your finger. Works great for silicone, bathtub, window caulk etc. Nice smooth pro looking job. Ice works good, I take all my coffee cups I use on the boats and cover the bottom with 1/4" of silicone and smooth it with an ice cube. Looks good and great non skid for boat use.
Oh use black silicone for outdoor use.
The clear will be eaten by UV light in a year and leak. Black is unaffected by UV rays.
Old 10-26-2010, 12:25 PM
Topgun2mo Topgun2mo is offline
I would stay away from silicone. Nothing for it to stick to(unless you make a large mound) and NOTHING sticks to cured silicone, not even silicone. Silicone contamination is a big no no in aerospace applications. For a no weld fix, concave the area and use a filler with metal in the base (Sand to metal first). If you want to retain the roof rack capability should you change your mind, fab up a couple of metal pieces to be held in place using a gasket or even something similar to the current rack mounting system.
Mike Morgan
Slidell, LA
'90 Grand Wagoneer
SOA, CUCV 14 bolt rear, 4.56 and Detroit, Looking for HP Dana 60 for front, 1" Body lift, 44044 Rancho Springs up front, Dodge 4x4 Rear leafs and shackles, BJs 1" lift shackles in front.
Old 10-26-2010, 08:13 PM
86gwrhino's Avatar
86gwrhino 86gwrhino is offline
We used 3m marine sealant and carriage bolts for the actual rack holes, and rivets and sealant for the rib holes.
'86 Grand Wagoneer
Chevy 350 TBI
Rhino grill
rusty's 4in all spring lift
'67 (i think) M715 all stock w/pto
Old 10-26-2010, 08:21 PM
FSJ Guy FSJ Guy is offline
They are called "wellnuts" and any good hardware store (Ace) should have them in stock.
Ethan Brady
www.bigscaryjeep.com
Old 10-26-2010, 10:23 PM
El_Diablo's Avatar
i actually have a package of 25 NOS well nuts if anyone needs them.... enough to do a roof rack and air deflector and still have some spares
pm me if you're interested so the thread doesn't get to far off topic
Old 10-26-2010, 11:00 PM
rmorit01's Avatar
This is how the "plastic" plugs work that i picked up from the local ace hardware for about .89 cents - they go into the old "well nut" holes
The outer piece is much bigger than the piece that fits in the old hole -- marine or automotive sealant around the edge and I have had no leaks for the last 7 months -
79 Cherokee S
Removing Roof Rack Christiansok General FSJ Discussion 18 05-19-2010 01:41 PM
Leaking Roof / Luggage Rack rjgrippin General FSJ Tech 3 05-22-2008 10:50 AM
Roof rack installation - a moment of clarity F. Townsend General FSJ Tech 0 10-26-2006 04:53 PM
Review - Tad Rack Brackets for stock roof rack Jeepeta Body 8 01-26-2006 12:12 AM
? on removing factory roof rack Woody Mammoth General FSJ Tech 10 05-04-2001 04:45 AM
