Go Back   International Full Size Jeep Association > Classifieds > "Look Here" for Parts, Vehicles and Vendors > Homegrown Vendors: (Members who produce FSJ related items)
Old 08-30-2009, 08:58 PM
Replacement head light adjusters
https://www.ebay.com/itm/1974-1978-Jeep-Grand-Wagoneer-Cherokee-J10-J20-headlight-adjuster/114352076455?fits=Make%3AJeep&hash=item1a9fea36a7: g:saIAAOSwqLRcI-DL
https://www.ebay.com/itm/114781837226
I have made replacement adjusters out of metal to replace the plastic ones the factory used. I wanted something that would last, and plastic aint it.
I'm selling them in sets of 4, so you can do both lights.
Round, $30 shipped
and square, $35 shipped
https://uploads.tapatalk-cdn.com/201...77ac10e568.jpg
Here is a write up on how to install them, Thank you Heavy_Metal_Thunder_81
https://www.dropbox.com/s/frf9sli823ptvf2/Square%20headlight%20adjuster%20writeup.pdf
E-mail me at- aberw3az@hotmail.com
Thanks.
46 cj2a
51 Willys p/u
'51 Willys Parkway Conversion
'74 CJ5
'75 J-20 Wrecker
'75 J-20 Cummins service bed
'77 J-10 p/u
'79 Cherokee
'88 Grand Wagoneer
Old 08-30-2009, 11:30 PM
HOOT's Avatar
HOOT HOOT is offline
How are you keeping the adjusting bolts from backing out?
You got some kind of cinch type thread or something?
Tom Gibson
1980 J20 Utility bed truck. Factory cab and chassis truck. Many new mods for it but it will look all stock.
1985 J10 nothing special just a nice clean stock truck.
2017 Challenger. Very jealous of the Jeeps.
Old 08-31-2009, 08:58 AM
With the spring on the one corner, they have held themselfs just fine. I have had a set on my J-10 for 3 years and have never had to readjust them. They have enough pull from the spring to hold them. I drive on several washboarded roads around here and they do great. My '88 has had them for a year, and same results. Both are round lights. The original plastic ones were not a lock style either.
46 cj2a
51 Willys p/u
'74 CJ5
'75 J-20 Wrecker
'77 J-10 p/u
'79 Cherokee
'88 Grand Wagoneer
Old 09-01-2009, 08:59 PM
vintagetrks's Avatar
bump
New Full Size Jeep Nut
90 Grand Wagoneer "Big Mama"
Old 09-02-2009, 08:25 PM
sflier sflier is offline
I just received a set for square headlights and can tell you that they are very well made. Fast shipping too. Thanks!
Old 05-21-2010, 09:14 PM
serehill serehill is offline
Gone,Never Forgotten.
Just paid for 2 sets
PIF Jaber!!!!!!!!
Old 05-22-2010, 10:12 PM
j10jim's Avatar
j10jim j10jim is offline
Just ordered a set!
1980 J-10<br />Rusty\'s 4 inch lift<br />2 inch body lift,<br />35 in Xterrains on J20 axles<br />4:30 gears<br />Detroits<br />In-Cab cage thru the dash
Old 01-21-2011, 09:20 PM
Here's the low down on these
I am buying a second round of these. Two sets both times. These are the greatest way to fix the nylon junk that comes on the round/Square headlights of both Cj's FSJ's. The reason I'm buying another double set is because a neighbor saw them on my lights & wanted a set to fix his 69 AMX!!!!! They worked for that too!!! I have seen questions about whether the bolts will back out & I can ensure you they won't. This is truly plug & play. Remove the old rivets & screw or rivet these right in place of the old ones. Mine look like they are factory.
THANKS JABER!!!!!!!!!!!!!!!!!!!!!!!!!
Old 04-21-2011, 05:53 PM
Tin Medic's Avatar
Tin Medic Tin Medic is offline
Loose (lug)Nut(s)
Are these still available?
Sons Waggy - 89 GW 360/727/208, 30x9.5x15 Destination M/Ts, Warn Lock Out Hubs, Razor Grill
Tramp - 85 CJ-7 Renegade FI 258/T5/D300, D30 w/ARB Air Locker, AMC 20 w/Posi Unit, 33x12.5x15 Goodyear MT-R's, Hella E-Code lights, VIAIR OBA System, Warn 8000lb Winch
Old 04-22-2011, 06:42 AM
Yep....
46 cj2a
51 Willys p/u
'74 CJ5
'75 J-20 Wrecker
'77 J-10 p/u
'79 Cherokee
'88 Grand Wagoneer
Old 05-08-2011, 11:22 PM
JP29 JP29 is offline
Nice
THANK YOU I would love a pair for my wag send me a pm if still available!! ever since the plastic broke on my wag it has been hell.
Old 08-16-2011, 11:05 AM
Jeff, do these fit the buckets for the rectangular lights too?<Never mind it says "and square" - but I did not recognize the bucket without the rectangular bulb in it.> PM sent.
Old 08-16-2011, 07:38 PM
PM sent.
And yes, I'm still making them.
46 cj2a
51 Willys p/u
'74 CJ5
'75 J-20 Wrecker
'77 J-10 p/u
'79 Cherokee
'88 Grand Wagoneer
Old 08-16-2011, 07:53 PM
Hey Jeff
News flash Mine on my new Commando project are messed up & ruined because the screws are rusted into them . I just got in from the shop & guess what fixed them?? The extra set I got fom you worked on my 72 Commando.
Another you can add to the list. BTW that should mean they will work down to 66 & these buckets are different form CJ's Thanks again.
Old 08-16-2011, 08:21 PM
Bryans89GW's Avatar
Bryans89GW Bryans89GW is offline
Where do i order these?
Old 08-16-2011, 08:40 PM
Just click on Jabers name at the top of this thread
Click on send Jaber a PM send him your info including Email & he'll contact you.
Old 10-01-2011, 09:33 PM
Tripwire's Avatar
Tripwire Tripwire is online now
PM sent
Abort? Retry? Ignore? >
Old 10-03-2011, 08:24 PM
Tin Medic's Avatar
Loose (lug)Nut(s)
PM sent.
Old 10-04-2011, 06:26 AM
Replied.
Thanks guys...
46 cj2a
51 Willys p/u
'74 CJ5
'75 J-20 Wrecker
'77 J-10 p/u
'79 Cherokee
'88 Grand Wagoneer
Old 11-07-2011, 09:07 PM
polarfire's Avatar
polarfire polarfire is offline
Just got mine in the mail today and already installed the passenger side! Fit perfect! Thanks a million!
'78 Cherokee S Levi's 4-Door (SOLD)
'84 J10 Shortbed
'83 Cherokee Chief WT (SOLD)
'82 CJ-8 Scrambler
'77 CJ-5 Renegade
