I think I am ultimately going to go to an electric Holley Red Top...but want to fix the issue first. It is a bit long...but I have 3 big questions.
1) How do I plumb this in on the carburetor end? The hard stainless line screws into the mechanical pump. If I eliminate the mechanical pump...how is that steel line supported??
2) Is a Rotary Vane (Carter/Holley) better than a Solenoid (Carter/Airtex)? Everyone seems to like the Rotary Vane design...but the Solenoid design is not supposed to have any rubber diaphragm that gets deteriorated by ethanol.
3) Anyone have issues with fuel tank delamination? I have the stock plastic fuel tank...I know some brands of plastic tank have had issues with delamination due to ethanol.
Below is a brief history if you want/need to read...
The shop swears they have fixed the issue...they said it was just out of gas. They filled the tank (with 5-gallons) and said all was right in the world. Last time I knew...we had a 20-gallon tank. Seems odd that I could only use 1/4 of it. So, I am not overly confident the issue is repaired.
Last summer (about a year and a half ago) I replaced the fuel tank strainer / sock / whatever you want to call it. I noticed some large black flakes in the tank. Cleaned them out as best I could. Ran great for about a year. Then this last July I started getting issues with fuel delivery. Not sure if it was starvation, vapor lock, or what. I have replaced all rubber lines, new fuel pump (mechanical), new fuel filters, carb rebuild...the problem would seem to go away for a short time and then return.
I have verified that the fuel pump works within spec (both pressure @ 6.5", vacuum @ 12", and supply). And I have verified that the fuel filter works. The only thing I haven't checked is the fuel tank strainer / sock. It dawned on me a couple days ago that if this thing is plugged, it would increase the vacuum that the supply line is under. Increased vacuum means decreased boiling point for the fuel. So, if the fuel sock is partially or fully plugged, it could increase the vapor lock situation. So, today I plan on testing.
According to the FSM, I need to "T" a vacuum gauge just before the mechanical fuel pump. Then operate the engine at 1500rpm and monitor the vacuum reading. It should not exceed 3" vacuum over the course of 30-seconds. In addition, I plan on placing a clear fuel filter right before the "T" for the vacuum gauge. I want to see if there are any bubbles indicating a pinhole leak in the fuel lines.
I will post up my findings. Like I said above, ultimately, I want to fix the underlying problem. But, regardless, I think I am still going to switch over to an electric pump. If I am going to keep this, it needs to be 100% reliable. From everything I have read on numerous forums for numerous vehicles, the underlying recommendation is that a mechanical will work...but an electric is a bit better.
