Old 08-15-2019, 08:43 PM
JTD's Avatar
JTD JTD is offline
New from Wyoming with a 79 Wagoneer
Hello. New from NW Wyoming. I just purchased a pretty solid 79 Wagoneer. Great runner! I of course already took out the interior and exposed the floors. As expected, I will be replacing the floor pans in the front. The cargo area floors are flawless. The purpose of this build will be for trails and hunting, So I will be installing a full vinyl floor instead of carpet. She will be getting a 3" lift and custom roof rack w/ a small winch attached to pull up my hunt kills. Some may not like this, but the faux wood paneling will be removed for good. Here's a link with some pics before I do anything.
https://pix.sfly.com/AWp-cz
Old 08-15-2019, 09:19 PM
78 WIDETRAC's Avatar
Welcome
Looks like a great wag.
Old 08-15-2019, 09:24 PM
Welcome. 79 was the highest production year for FSJs. Seems like a ton of them still out there. I always like the clean look of a Waggy busted out of the wood crate.
Old 08-15-2019, 09:35 PM
JTD's Avatar
JTD JTD is offline
How does one know which transmission (THM400, A727 or the A999) or which transfer case I have (Borg or Dana)?
Old 08-15-2019, 10:29 PM
jeepdan's Avatar
jeepdan jeepdan is offline
Nice Wagoneer! Wow, I wish that I didn't live in the rust belt
I had a 79 four door Cherokee S that I bought brand new for $9750 in Oct 1978. My first vehicle.
Your jeep should have the turbo 400 with the Borg Warner Quadra trac transfer case.
2016 JKU Black Bear (daily driver)
91 Grand Wagoneer (in storage)
67 Kaiser M715 (frame off restoration)
64 US Army CJ3B (frame off restoration)
66 M416 trailer (original "nice" condition)
Two unrestored 56 Willys trucks (one a pickup, one a stake bed)
Old 08-16-2019, 06:30 AM
JTD's Avatar
JTD JTD is offline
Thanks. I figured since I have the low range lever on the floor, that I must have the BW1339 transfer case.
Old 08-16-2019, 02:47 PM
Yep, you have a TH400/QT. WOW! and the OEM CB/AM/FM stereo!! If you pull it out, let me know and I will buy it from you.
Awesome rig to start with! I'm excited to see you put it together.
Old 08-16-2019, 10:13 PM
JTD's Avatar
JTD JTD is offline
Ya. Love the radio/CB combo. I have to figure out how to repair it. It seams to power up, but neither the radio or CB seem to operate. Have have yet to dig into it.
Old 08-17-2019, 10:48 AM
Driftwood's Avatar
Welcome!
Nice color. Looks like "9A" Alpaca Brown metallic. It appears to be a Limited edition with the glove box badge and the wood paneling.
Your transmission is a TH400. And the transfer case is a Borg Warner 1339 QuadraTrac
I have similar problems with my CB/AM/FM radio. It doesn't power on at all. And I ditched the inoperative analog clock and replaced it with a delete plate. I hope to find a digital clock soon. I bought one off ebay and the chump that sold it to me failed to say it didn't work.
1979 Wagoneer
Old 08-17-2019, 05:41 PM
Nice. And welcome. 79 was a good year for FSJ's. Pretty as-is reliable stock rigs if maintained properly as opposed to modifying/improving(?) them. FSJ floor pans rust out from the inside-out from the painted floor getting wet and not drying out so I personally would NOT install a vinyl or rubber floor covering over new floors. The floors/carpet/backing needs air circulation to dry out. All the vinyl does is trap moisture. Soggy/wet carpet never ends well long term. I'm no expert but the exterior trim looks almost like a newer (GW era) trim package. Though I don't endorse many mech modes as improvements, I strongly support losing the plastic fake packing crate.
Old 08-19-2019, 12:47 PM
miracleed's Avatar
miracleed miracleed is offline
Welcome! Have to say that I admire your taste in vehicles.
'79 Wagoneer Limited
Old 08-21-2019, 08:36 AM
chubbinius's Avatar
Welcome to the boards. Nice looking ride and a good year too. I second the not using vinyl, but if you do, consider using POR-15 or a similar product to seal up the front floors after you replace (and maybe even the cargo area to keep it protected too). See you around the boards!
1970 1414X Wagoneer "The Pig"
-Dauntless 350 V8
-D27 front/D44 rear
2006 XK (65th Ann Edition)-DD
Old 09-19-2019, 09:27 PM
Safety Andy Safety Andy is offline
If you still want one of the CB/FM/AM combo. I’m fairly certain I saw one in the Watson and Son FSJ Salvage yard in Pinetown NC.
1979 Wagoneer Limited
Old 09-20-2019, 09:32 AM
Copy that! Good lookin out!
Old 09-20-2019, 10:39 AM
miracleed's Avatar
For some reason just now able to see the pics... Man your beast is in a lot better shape than mine! Kudos on that CB too... I'd probably cut off a toe for a working original CB/AM/FM.
Old 12-04-2019, 01:15 PM
bluehwy's Avatar
bluehwy bluehwy is offline
Great looking rig! Looks to be in much better shape than my '79 when I got it; great score.
Previous: 1988 Grand Wagoneer
Current: 1979 Wagoneer
"Well I've been down so GD long! and it looks like up to me..." Furry Lewis
Old 12-06-2019, 09:28 AM
Wagoneer Taylor's Avatar
Welcome, as like most of the others have said "great looking rig". I think we all get excited when we see one that looks good and isn't in need of a full tear down like mine
Also not sure if you already have a lift kit picked out (or what exactly you are looking for) but Rough Country makes a 3" lift kit that is not too expensive and is what I plan on going with eventually. I was very particular in wanting a 3" lift nothing more or less. But BJs Offroad makes several kits in a couple lift ranges if you are looking around.
Some call me Taylor...
Pewter, Blue Interior, Original 401
PO swapped in a 360, soon to be a 401 again!
"Soon" is a relative term.
Cracked cylinder put a hurt on me + bad connecting rods.
1983 Wagoneer Build Kansas_Nova General FSJ Tech 69 12-24-2015 06:09 PM
(Not So) New 86 Grand Wagoneer Orion1188 General FSJ Discussion 9 12-04-2012 02:59 PM
Wagoneer owners here in Montana are dangerous men! Hartman General FSJ Discussion 16 06-16-2011 10:28 PM
First wagoneer camping trip. MikeinColorado General FSJ Discussion 22 06-14-2011 11:40 AM
Grand Wagoneer To Wagoneer Grill Swap BARsSS General FSJ Tech 1 03-28-2005 09:56 AM
