Old 03-20-2007, 10:41 AM
77orange 77orange is offline
drip drip drip
I am well aware that my vehicle is 30 years old and is going to drip a little oil. I recently have developed a small coolant leak though that I can't seem to stop or locate. It drips off the front of the oil pan on the drivers side. It is a very slight drip that leaves a small mark on the ground. Two qusetions;(1)Where to search for the leak and (2)Should I be concerned about a cracked block? Thanks in advance.
1977 Cherokee, 360 w/3spd, BJ\'s 4\" lift, TFI upgrade, msd 6A, comps cam 260h, double roller timing set, headers
Old 03-20-2007, 10:50 AM
J4GRAND's Avatar
J4GRAND J4GRAND is offline
J4000 Restoration Specialist
I would check the bottom radiator hose/hose clamp and the weep hole on the bottom of the water pump. I had a bad pump that started to weep and the leak appeared in almost the same spot you describe.
Patrick V.
MEMBER #14
78 Cherokee Chief WT "Old Blue" 360 V8 4V TH400 QT
05 Jeep Grand Cherokee 3.7 V6 5 speed automatic with new QT
Old 03-20-2007, 11:42 AM
Thanks, I did not realize there is a weep hole. Maybe thats what I have?
Old 03-20-2007, 12:43 PM
chrisnsarah's Avatar
There are also 2 weep tubes in the timing cover at the water passages. If the water passages get eaten away, the leak is directed outside instead of to the oil pan.
Also, check all your core plugs, including the small ones in the head, head to intake joint, the thermostat housing, CTO switch, temp sensor, and bypass hose.
'64 J200 thriftside
'67 J2000 townside custom cab
'68 Jeepster Commando
'69 Super Wagoneer
'75 J10
'79 Cherokee S WT
'75 Cherokee
'61 Aristocrat Lil Loafer
