We have replaced the freeze plugs on the rear of both sides of the block. It wasn't too bad. Now I need to replace the freeze plug on the front of the driver's side. It mostly covered up by the engine mount. I don't have an engine hoist, so should / can I replace it without removing the mount? If so, how - it doesn't look like there is enought clearance to get the new one in.
If I do need to remove the mount, do I just support the engine with a floor jack and remove the mount? I've never messed with engine mounts before...
