Old 08-07-2017, 10:59 AM
vickmorrow64 vickmorrow64 is offline
Tranny of transfer case issue?
Spent months getting mechanicals correct on my 85 GW . When I purchased car it would turn over but not start - finally got it started and it sprang some fuel leaks - fixing that this week - when I went to put in gear and try to run it up ramp on uhaul car transporter it would not go. I moved shifter around and it feels like it is engaging - a friend looked at it and thinks it is the transfer case - any way to test his theory? I topped off all fluids in tranny and transfer case - so that can be ruled out.
Old 08-07-2017, 11:01 AM
I have NP229 transfer case and a parts vehicle with a No229 in it - tempted to swap them out
Old 08-07-2017, 11:19 AM
CutterN55's Avatar
Did you check the Hi/Lo lever on the floor under the seat? Make sure the linkage isn't sloppy there as well.
ROMANS 12:1-2
'89 GW deceased
Ford 4spd swap Np435/205
Old 08-07-2017, 11:36 AM
72jeeperjoe's Avatar
72jeeperjoe 72jeeperjoe is offline
Sounds like transmission to me. I would check to see if the transfer case is stuck in between setting first and check your transmission linkage too. I have experience with the same issue, if there is no engagement and it is going into gear it sounds like the clutches in the transmission are burnt up.
1983 Jeep Wagoneer-322,000 miles.
1972 Jeep Wagoneer-360-auto-sold
1988 Jeep Grand Wagoneer-One owner-64,000 original miles-Sold unfortunately
1968 Jeep Gladiator, full Resto in progress
1963 two door ifs one owner Wagoneer
Old 08-07-2017, 12:24 PM
Atlasts's Avatar
Atlasts Atlasts is offline
Transfer case
I just went through the same type of issue. After getting my J10 running, it would not move in gear. I found it was the hi/low case was not engaged all the way so I manually pushed the lever toward the rear of the truck and that fixed my issue. I didn't have to remove the linkage as mine is cable driven and it had enough slack for the lever to engage.
Old 08-07-2017, 01:07 PM
I checked the hi-low and that is fine
Old 08-07-2017, 01:32 PM
Did you manually move the linkage and verify?
Old 08-07-2017, 03:28 PM
Frank Ziebert's Avatar
Update please.
Old 08-14-2017, 06:37 AM
Will try that this week - thx
Transfer Case Linkage Issue temps425 Off-Road FSJ Tech 3 05-19-2010 12:05 PM
Transfer Case Question WagoneerMan General FSJ Tech 5 02-05-2010 10:19 PM
401 tranny / case options... Richomino General FSJ Tech 3 09-06-2007 06:20 AM
J20 with automatic and dana spicer 20 transfer case soxcloud General FSJ Tech 3 03-09-2007 02:44 PM
Transfer Case cracked driving to work today vistalite General FSJ Tech 5 04-21-2005 09:54 AM
