  #1001
Old 12-24-2019, 05:35 PM
rws31's Avatar
rws31 rws31 is offline
[quote=Full Size Jeeper]
[/wasn't that just the most fun you ever had getting to replace all that?QUOTE]
No way I would have wanted to put them back together during the summer months when it's 98.9 degrees. Very happy to be done. They sound so solid with all the glass and rubbers back in.
That is a nice sound isn't it.
It's all looking good, nice work.
89 GW, 454, 700R4, 241C, 411's with posi's, 9" rearend, 2500 stall, lifted, and lots more to do.
1988 Ramcharger
1999 International 4700 Crew Cab 4X4, custom step side bed
2003 Durango 4x4
1982 CJ7 4 banger
2008 MB E320 Bluetec
Old 12-27-2019, 01:47 AM
Full Size Jeeper's Avatar
Full Size Jeeper Full Size Jeeper is online now
Thanks all for the comments. Working on the window wipes on the passenger side front door, Two of the clips came out on the outer wipe. I'am going to try and order some clips and redo it. Not sure if I can fix it, we will see. Also All the other wipes I very gently hammered all the tabs down a little.
1978 Wagoneer
Mods:
Old 12-27-2019, 01:54 AM
The rear wipes went in okay. The outer wipe was to long for the drivers side rear door. Was able to cut it to length on my band-saw with out screwing it up. The wipes were the same length, I think the drivers door was built a little shorter. Go figure.
1978 Wagoneer
Mods:
Old 12-27-2019, 02:01 AM
Started working on trying to make a gasket for the tail lights. I found some D profile rubber weather stripping at Home Depot and cut it to make it work.
Here is what I used.
1978 Wagoneer
Mods:
Old 12-27-2019, 02:06 AM
My taillights are not in the best of shape. I have a set off of a parts Wagoneer that are in a little better shape, so I will use those. I used the 3M black weatherstrip adhesive.
1978 Wagoneer
Mods:
Old 12-27-2019, 02:09 AM
Cut the flat part of the D profile off and glued it to the housing.
1978 Wagoneer
Mods:
Old 12-27-2019, 02:10 AM
1978 Wagoneer
Mods:
Old 12-27-2019, 02:15 AM
Came out pretty good.
1978 Wagoneer
Mods:
Old 12-27-2019, 06:17 AM
rws31's Avatar
Be careful when you get the new clips. My drivers door clips were off and it wouldn't fit. The clips broke when we tried to remove them.
Ordered what I thought was the same clip and put them on the wipe only to find that it held the wipe to high.
Hear is the old clip versus the new one. Notice the spike location is off. It was usable but took some extra work to get it in.
IMG_20191019_093507861 ,
1988 Ramcharger
2003 Durango 4x4
1982 CJ7 4 banger
Old 12-27-2019, 03:10 PM
Originally Posted by Full Size Jeeper
Also is this where the wipe should be? I don't remember a big gap right here. Should I try and push it forward a little.
Mine fits exactly like that, too. I still have the factory front seal on vent windows so I think the new scrapers should have a little wing on them that comes forward to cover that gap. I am not sure what I am going to do about it either. I do not see a way to move the scraper forward and even if you do, it will just expose a gap on the other side.
79 Cherokee Chief
Old 12-27-2019, 03:21 PM
SOLSAKS's Avatar
SOLSAKS SOLSAKS is offline
that mcguyver tail light gasket looks really nice.
dave in NC
Old 12-27-2019, 03:30 PM
Originally Posted by DarkMonohue
Memory is weak here but I believe Strode encountered the same issue on his Cherokee build. Might be worth revisiting his build thread.
Just read through his thread. His similiar issue starts on Post 493.
http://www.ifsja.org/forums/vb/showt...157145&page=13
79 Cherokee Chief
Old 12-30-2019, 11:28 PM
Cleaned up these trim pieces and installed the smaller ones today.
1978 Wagoneer
Mods:
Old 12-30-2019, 11:31 PM
Used the 3M trim adhesive, put a little on both pieces and slap it together.
1978 Wagoneer
Mods:
Old 12-30-2019, 11:37 PM
Christmas put a hurt on the Jeep piggy bank so I'am doing things that are not costing a lot of money. Just trying to keep the project moving forward.
1978 Wagoneer
Mods:
Old 12-30-2019, 11:41 PM
Also cleaned up the rear door sill protectors. I used a product called White Diamond and Mothers aluminium polish. Before.
1978 Wagoneer
Mods:
Old 12-30-2019, 11:43 PM
Cleaned and installed.
1978 Wagoneer
Mods:
Old 12-31-2019, 04:52 AM
rws31's Avatar
Looking good. Were those plastic trim pieces already black?
This time of year does put a damper on the ole piggy bank of Jeep money.
The sill plates look great but I bet they were a bear to polish up. Kind of like waxing diamond plate.
1988 Ramcharger
2003 Durango 4x4
1982 CJ7 4 banger
Old 12-31-2019, 08:44 AM
Yes, the trim was black. I washed the sill plates with dawn dish soap and then hand polished with white diamond and mothers, was not to bad. The black trim was cleaned with dawn and hot water.
1978 Wagoneer
Mods:
Old 12-31-2019, 02:42 PM
Holy cats! What a difference those sill plates made!!! They look NOS!!!
79 Cherokee Chief
FrankenJeep (Turbo Wagoneer) build thread Ghinmi Street & Performance 230 10-04-2015 09:11 PM
How tall for a daily driver / mild off road Wagoneer lorenmjones General FSJ Discussion 18 09-11-2014 05:57 PM
Build thread - 3x Grand Wagoneer 89/90/91 sportsidedan General FSJ Discussion 22 09-03-2013 12:11 PM
