Old 07-22-2009, 06:33 AM
scotty1998's Avatar
scotty1998 scotty1998 is offline
How to replace the door handle return spring
So every since I've owned my rig, other than the phantom door lock drop, the thing that really annoys me is that the inside handle on the driver side door has a bad/broken return spring. If you don't physically push the handle forward after the door is opened, the door will fly back open while driving when someone unsuspecting gets behind the wheel (like a friend).
1) How do I access this spring
2) Can it be replaced with something OEM or similar?
Thanks
1987 Jeep Grand Wagoneer
Stock Everything
AMC 360, 2-BBL Motorcraft
Old 07-22-2009, 12:11 PM
dbuie dbuie is offline
I wish you had posted this several days ago while I had my pass door torn apart and then I would've been glad to help you better. But, based on memory you will have to take the inside panel off. Raise window if not already raised. Then loosen the torx bits on the outside of the door. Then you should be able to reach in there and see how it all fits together. Wish I could help you more but that's the best I can do from memory. While you're at it, lube the heck out of everything that moves. I did this on mine and now all door functions are smooth. Could be your problem.
1989 GW-Resto Project
My "Labor of Love"
Old 07-23-2009, 06:39 AM
scotty1998's Avatar
Thanks for your help.
I know the spring is gone because I found little pieces of it in the bottom of the door when the rig was new (to me). I guess I was just wondering if there's an actual replacement spring you can buy or something that could be matched up.
Stock Everything
Old 07-23-2009, 09:40 AM
Maryland Rick's Avatar
Maryland Rick Maryland Rick is offline
Go to this site. Troubled Child sells the springs. I did mine last year. Not a real hard job.
Rick
http://tc.wagoneer.net/sblog/static....ge=doorsprings
Old 07-23-2009, 10:57 AM
Thomas792's Avatar
Thomas792 Thomas792 is offline
If you are talking about the spring that returns the handle to the forward position then below is for you. If you are talking about the spring that keeps the door from accidently locking the Troubled Child sells them with a nice write-up for most years.
I did mine a year ago but cannot remember all the details. I pulled my door apart and actually removed the bracket tha holds the little splined shaft with the bellcrank assembly and the arm (held together with screws as near as I can remember). Then I bent the little tabs straight that hold the U shaped bracket and surround the spring and splined shaft. Then I figured as best as I could how I wanted the shaft to line up and bent the coil spring flat at that spot (very stiff wire). I put the U shaped braket back on and bent the tabs back and reinstalled everything.
1974 J10 (401, Th400, Q-Trac, D44s, 28" tires)
Mrs Tickity - 1988 GW (360, 727, 229, D44s, 32" tires)
Old 07-23-2009, 04:47 PM
Sorry..............I jumped the gun and thought that you meant the door lock spring.
Rick
Old 07-23-2009, 09:05 PM
scotty1998's Avatar
No worries Rick. Yes, i was talking about the spring that returns the handle to the forward position but quite frankly I have the phantom drop lock syndrome on my passenger door so now I know where to get the retainers I think I just need to get inside the door and find out what I'm up against. Thanks for all your help guys.
Stock Everything
Old 05-01-2015, 03:47 PM
jeepgirl's Avatar
jeepgirl jeepgirl is offline
I found the broken pieces of my handle return spring in the bottom of my door. Anywhere to get replacement?
Thank you
"Silly boys.. Jeeps are for girls!"
1978 Cherokee Chief "Ivy"
Old 05-02-2015, 08:52 AM
Dbshea Dbshea is offline
Thank you
I just replaced mine with a junk yard donor, but for about 6 months my shade tree repair was to use an extra throttle return spring. I drilled two small holes about 1/8" apart under the striker on the back edge of the door (for one side of the spring to hook) and another about midway along the metal bar that connects the handle to the door mechanism. It wasn't the most beautiful thing in the world but it kept the door shut
Old 05-05-2015, 08:08 AM
chrism chrism is offline
From what I understand you just need to replace the whole assembly. Mine is shot too on the driver side and I plan on getting in there and maybe swapping the driver side rear door assembly if they are similar while I look for a used part.
1979 Cherokee
1979 CJ-7
Old 05-20-2015, 06:42 PM
I found what looks like the right spring on an AMC parts website and I plan to order one to test, but it's not high on my list yet.
Old 05-21-2015, 07:11 AM
Jwilly's Avatar
Jwilly Jwilly is offline
If it is the correct one could we get some measurements from it? Mine are all broken/missing. I wanted to see if maybe they could be bought from a shop. Thanks
http://www.allrite.com/inventory/des...ing-calculator
http://www.allrite.com/inventory/clock-springs
Old 02-18-2020, 02:23 PM
Beach_Dude's Avatar
Beach_Dude Beach_Dude is offline
Any new updates on these springs?
1977 Jeep Cherokee Chief
360 w/ MC 4350
Old 02-18-2020, 06:51 PM
Tripwire's Avatar
Tripwire Tripwire is offline
I would be that you could take one from a rear door and use it on the front as the fronts see a helluva lot more wear than the rear ones
Abort? Retry? Ignore? >
Old 02-20-2020, 12:03 AM
Jeeper555 Jeeper555 is offline
Too bad those links to the spring stores aren't working.
Old 02-20-2020, 09:11 PM
pyro's Avatar
pyro pyro is offline
I just did like the above and got a rear door spring. Had to fab up the linkage as it is different from front to rear. I'm back working 100% again though.
'81 J10 Laredo 258/T176
'82 Cherokee 258/TF904
FSJNetwork Florida FSJ's Click Here!!!
Old 02-22-2020, 12:07 AM
letank's Avatar
letank letank is offline
one way is to use a newer electrical door lock motor, the spring is stronger. This is what I did and it has been 1O years
Michel
Old 03-27-2020, 05:48 PM
I got a little wrapped up with recovery from heart surgery and dealing with moving and sorting our whole life to finish looking into this. I wish I had bought the crate of those springs at Boeing Surplus about 20 years ago now. Less than scrap value at the time. I think they were spare parts for the CJ10A tugs and some 737 equipment. I looked up the skew once a long time ago.
Old 03-30-2020, 06:25 PM
I just bought two springs on Ebay for a '58 Dodge sedan [because they look correct] and they were.. I believe there are others on the site too and they're not expensive. So, by a set and try them.
Old Today, 02:08 PM
jeepgirl's Avatar
Finally fixed the partially working inside driver door handle. Basically, the main spring broke so if you didn't push lever back after use and tried to shut the door it wouldn't latch and just swing open.. there is no new spring replacement so I had to find a similar spring, dismantle, and reengineer the mech.. so far so good!! 🤓
The part I used was a 1936-1938 plymouth truck hood handle lock latch spring which I found on ebay for about 22$ for the pair. The spring is about 180 degrees off but I just cut a small notch in the mount and problem solved. I have pics of the ebay ad and the required modification so just PM if interested...
