Well I just found a D60FF out of a J20. I'd like to know if this is a pretty straight forward swap. I don't know the gear ratio yet, but i'm also getting the front end, so i can swap the gears if i need to. Will the drive shaft hook up to this d60? Also I will be planning on doing a front d60 swap too. So when i find a ford high pinion d60 then i'll swap that in after. Does anyone know if the d60 out of a jeep is goign to be a lot more narrow than a front d60 out of a ford? I know that the front will always be wider, but i'm trying to find this out for the long run. Thanks for any help, also anything i should look for doing this swap, let me know. thanks!
wanna swap my amc 20 for a Dana 60
