Old 07-28-2015, 09:56 PM
DBX11's Avatar
DBX11 DBX11 is offline
timing light troubleshooting
Interesting discovery today; intermittent rpm on plug wire #7. So I wiggle the wire and rpms return and a small tick,tick goes away... Let pressure off and tick,tick returns and rpms go back to zero. I suppose a bad crimp on the msd wire is causing this. So without touching the wire with anything but the timing light lead I increase the rpms and watch the light change from 0 to 1200ish and when I let off again it returns to 0. This only happens on #7 wire and rpms are there when the throttle is twisted and not when released.
When I get some time ill redo the crimp And check the plug and inside the cap but this method could be used if a fouled plug is suspected or in my case (hopefully) just a bad crimp although you need a digital type timing light.
Old 07-30-2015, 06:43 PM
will e's Avatar
will e will e is offline
Always Broke
Good for you. I discovered the same troubleshooting technique about 6 months ago when my #1 wasn't firing right. The RPM's were jumping so for grins I tried a different wire and it was steady. I had a cracked spark plug.
I wish someone made an affordable scope...
Old 07-30-2015, 08:04 PM
Actually, there is an adapter to hook to old TV sets. My buddy found one that he runs on his smartphone but he won't tell me what it is (It's supposed to be proprietary)
It's the little things: Light Bulbs KensAMC General FSJ Tech 21 11-02-2019 01:40 PM
Edelbrock 1406 Vacuum Port Question etprime General FSJ Tech 7 01-01-2015 09:51 AM
tail light question at the end of my rope!! jeepjseries General FSJ Tech 6 11-29-2009 10:33 AM
Dumb Question of the Day - Manifold Vac Vs. Ported for Advance scotty1998 General FSJ Tech 9 10-06-2009 05:01 PM
Doing distributor swap, need timing light advice. JoshRountree General FSJ Tech 27 08-17-2007 02:18 PM
