Old 05-12-2015, 12:51 PM
k13evin's Avatar
k13evin k13evin is offline
AMC HEI unit bulltear
looking to swap to the AMC HEI Bulltear.
any one running this? and whats the set up? one wire hook up or more?
1990 Grand Wagoneer AMC 360, Carb 2150
31x10.5/15 4in lift
200000 miles and still rolling
Old 05-12-2015, 01:24 PM
Strode's Avatar
Strode Strode is offline
1st Chair, Cowbell
One wire. I ran my existing hot start/crank to a relay as the trigger and ran a pure 12v to the HEI. One wire is reduced voltage while cranking I beiieve. (don't remember which color, but you can figure it out from the wiring diagram) It won't work for the HEI, but it works fine as a trigger. I think using a relay is the way to go.
Mine runs fine, but I'm kinda disappointed in the cheesiness of the spring and coil contact to the rotor. It's my 1st HEI, so I don't know if they're all like that or not. I think they are. But it runs fine.
Ristow's Bunker
Old 05-12-2015, 02:30 PM
you can get the same distributor on ebay for about 50 bucks.
Old 05-12-2015, 07:52 PM
k13evin's Avatar
50$ on eBay huh just take the old gear off and put on the new HEI distributor?
And does this bypass the ignition module so I can just scrap it?
31x10.5/15 4in lift
Old 05-14-2015, 11:28 AM
jeepsr4ever's Avatar
www.Bulltear.com Chief
No you cant. You can get the chinese equivalent for $50
AMC/Jeep Forum
Old 05-14-2015, 01:21 PM
Yes, it does away with the ignition module. It completely self contained.
2004 Jeep Liberty
1998 Jeep ZJ 5.9
1994 Jeep ZJ I6
1989 Jeep Grand Wagoneer 360
Old 05-14-2015, 08:51 PM
i wasn't aware anyone other than china/taiwan was making hei's. enlighten us as to where yours are made.
Old 05-15-2015, 06:12 AM
I've been running 3 White Performance HEI with 8mm wires [>$99] for 3 years now. I did swap the gears to be on the safe side. One wire hook up--10awg hot at the harness plug.
Old 05-15-2015, 10:22 AM
i've run 2 skip whites. one was issue free,the other was junk. they looked like they were from 2 different suppliers.
my brother bought a mallory 85 series a couple years back,chinese junk and it self destroyed in short order.
Old 05-15-2015, 11:09 AM
Probesport's Avatar
Probesport Probesport is offline
That's correct, but you could buy 4 of them for the price of the ones that you sell which is nice.
This is one part that I don't see the need to go to bulltear for, oil pump, mechanical parts? Every day of the week but a distributor? Too simple, too easy to fix. Even if you bought a cheap $52 SW off of eBay you can put all new guts in it, including a new HEI and still come out a bit ahead.
Ken S.
Megasquirt EFI
: Heated Seats : Blower fix : Driving light brackets : Shorty headers : Coil Packs : Electric Fans
Old 05-15-2015, 12:03 PM
All you need to know is the Chinese ones look almost identical. Skip white units are the Chinese ones.
AMC/Jeep Forum
Old 05-15-2015, 12:06 PM
You can buy a Chinese distributor and then youll need to swap the main shaft as well. Depending on the time of year, the rising of the sun and the attitude of the workers that made the main shaft on the Chinese distributor you can get one with the drive tang not cut deep enough. I say this after doing R&D on HEI units for AMC from 2003-2009 for several companies. We even had our own billet units we built with high end aftermarket guts. I still have all the models and blueprints for those. But as folks see it nowadays and I cant blame them .."why not buy a couple of $50 dizzys and get one that works for a while". That way you don't have to spend more.
AMC/Jeep Forum
Old 05-15-2015, 12:17 PM
Probesport's Avatar
I know i'm new here, but are you really against sharing your product info? Seems like a very snide remark to make to a customer base even if it is just an angry statement at one member.
Ken S.
Megasquirt EFI
Old 05-15-2015, 12:19 PM
Probesport's Avatar
It's about value, if your oil pump sets were 2 grand i'd probably still buy one. I feel your pain and completely understand as well. Me and my company made racing parts for about 15 years, we had a flagship product that was eventually copied out by the chinese market for 1/5 the cost (and quality) however under the conditions that 90% of my target market used, it performed just fine.
I also explained to any customer willing to listen how they could go about making their own and what was involved - the people that were going to made their own and the people who didnt want to invest 5 grand into the tooling and equipment to do it themselves did not.
All that said, everything must be taken with a grain of salt because I can build, machine, or make whatever I need so I may have an advantage over some DIY'ers.
Ken S.
Megasquirt EFI
Old 05-15-2015, 12:36 PM
Not snide at all just not willing to share anymore. I used to give out engine blue prints, sources for mfgs, helped the aftermarket make good parts for AMC engines for free and give out and give out and give out. Would it change your life if you knew these were made in Spain? Ristow is a decent guy...maybe wished he was willing to not throw his opinion in the ring where the fact is different. But we both shoot from the hip.
AMC/Jeep Forum
Old 05-15-2015, 12:42 PM
Probesport's Avatar
Yes, quite a bit I know more about labor regulation in Spain than I do in China so for me personally, I would now give your value a bit of a boost - I still think its over inflated for current market, but now worth easily double with that info.
Thank you for providing.
Ken S.
Megasquirt EFI
Old 05-15-2015, 12:46 PM
I don't need a boost I just need to get our parts out of this penny ante' market where people are constantly comparing quality parts with garbage. It isn't worth $30 we make on the distributor to argue about it online. Look at the parts in a Chinese distributor and you would quickly see the bushings are made out of a different material, the plastic is different, the measurements but they look similar. Skip white should be kissing my rear and anyone selling the Chinese distributor because the guys who originally had that clone made needed help and I helped them with measurements. Eventually they quit listening and the market flooded about 5 years ago. /crabby
AMC/Jeep Forum
Old 05-15-2015, 12:57 PM
Probesport's Avatar
We've all seen it, all of us who made niche parts. I can list off the same complaints for everything we made that was cloned. Resting on laurels will not help, complaining about the competition doesn't improve marketability.
Educate your consumers more, let knowledge and experience speak for itself instead of alienating an entire culture and those who may be customers that cannot afford a top tier brand.
This isn't the Rolls Royce board where people come to debate the merits of where their hidden in door umbrella was hand carved.
And since you don't need the boost, I retract all value based on the attitude and comprehension of the salesman.
Ken S.
Megasquirt EFI
Old 05-15-2015, 01:04 PM
i aint' attacking bulltear by any means. just saying all these aftermarket hei's look the same,and as far as i know,none of them are made elsewhere than china/taiwan. as i said above mallory is china now.
if someone is wanting 3 times the amount,it would be smart to put why,when most gearheads pretty much know these are all repacked chinese.
Old 05-15-2015, 01:05 PM
i bought a parts truck with a DUI in it. those are hi-buck. and it was cheap crap under the cap.
Resurrection Len in PHoenix General FSJ Discussion 55 02-24-2013 12:48 AM
Water Temp Sending Unit JohnIL General FSJ Tech 4 12-09-2009 09:42 PM
Hydroboost install into a later model wag. (writeup) JeepsAndGuns General FSJ Tech 9 02-27-2008 07:21 PM
Noticeable "temp" change with new sending unit yipcanjo General FSJ Tech 7 05-03-2005 11:54 AM
Oil pressure sending unit PhilSine General FSJ Tech 5 06-15-2003 07:30 PM
