Old 05-01-2015, 04:47 PM
rockrollin's Avatar
rockrollin rockrollin is offline
aluminum 727 pan
Anybody using one? If so how well does it clear the cross member. My current pan looks to have been run over by a tank. I flattened it out reasonably wel, but after a few months it starts leaking again. I can get a "stock" style pan, but I would rather have aluminum if possible. This will be #3 gasket replacement, not in a hurry for #4.
Thanks
OI!IIII!IO "I like fun" Eddie Ott
Clawed 90 GW
Slightly off stock
Old 05-01-2015, 07:12 PM
Tripwire's Avatar
Tripwire Tripwire is offline
i have one - its a little deeper than stock making access to some bolts chalenging/impossible, i notched my cross member and drilled a few holes to gain access.....get one with a drain plug...it makes the fluid changes easier
and DO not buy the crap gaskets, get the mopar lifetime ones make of plastic with twin rubber seals imbedded in them
Abort? Retry? Ignore? >
Old 05-01-2015, 08:23 PM
polarfire's Avatar
polarfire polarfire is offline
OEM deep trans pan available from the dealership P/N: P3690730AB
Works perfect.
'78 Cherokee Levi's 4-Door
'84 J10 Shortbed
'83 Cherokee Chief
'82 CJ-8 Scrambler
Old 05-02-2015, 10:51 AM
will e's Avatar
will e will e is offline
Always Broke
Works perfect.
That's what I did. Works great.
Old 05-02-2015, 12:31 PM
rockrollin's Avatar
Like this?
https://www.monicattichrysler.com/co...?idProduct=191
Is the flange any heavier than stock.
Clawed 90 GW
Slightly off stock
Old 05-04-2015, 11:31 AM
TexasJ10's Avatar
TexasJ10 TexasJ10 is offline
360 AMC
Any pictures of where you notched and drilled. This is probably the route I am going as well.
Old 05-05-2015, 07:52 PM
stonehengeheels's Avatar
stonehengeheels stonehengeheels is offline
Only $55 and you would rather drill and notch your cross member? Just curious.
Steve
'87 GW (Totaled)
'90 GW (Under renovation)
'00 GC Laredo (Totaled)
'02 GC Laredo (Sold)
'67 Dodge Coronet Convertible 440/727/3.55
Old 05-05-2015, 08:24 PM
Tripwire's Avatar
problem is the pan is so deep you cant get to the middle bolts easilly - or at all ( and i have fairly small hands) round holes are the best way to go- you only need a few...probably only a goo idea for a daily driver - light offroad, dosnt look to compromise the intergity too much
Old 05-05-2015, 09:16 PM
TexasJ10's Avatar
360 AMC
I would just prefer the rigidity of an aluminum pan. If I could find one that was only slightly deeper than stock, that would be great. I haven't found one yet.
Old 05-06-2015, 03:53 AM
rockrollin's Avatar
Originally Posted by TexasJ10
I would just prefer the rigidity of an aluminum pan. If I could find one that has only slightly deeper than stock, that would be great. I haven't found one yet.
Same here, but I admit I'm probably trying to over fix the bent pan issue. I'm not interested in drilling and notching the cross member. The one I linked is an inch deeper, but I haven't crawled under to see how access will be.
Clawed 90 GW
Slightly off stock
Painting Aluminum Radiator Tonka J200 General FSJ Tech 31 09-09-2014 05:23 PM
Jeep 727 tailshaft to Chrysler 727 Strode General FSJ Discussion 4 04-24-2012 05:35 PM
Cast aluminum 727 pans: what fits? austinaubinoe General FSJ Discussion 11 03-18-2011 06:59 PM
Chrysler (not AMC) 727 to NP229 ottocycle General FSJ Tech 1 08-14-2010 05:16 PM
looking for source for cast aluminum 727 tranny pan ccpanel General FSJ Discussion 11 03-08-2009 09:20 AM
