Go Back   International Full Size Jeep Association > Classifieds > "Look Here" for Parts, Vehicles and Vendors > Homegrown Vendors: (Members who produce FSJ related items)
Old 01-08-2018, 06:23 PM
Kaiserjeeps's Avatar
Thanks for posting. I was just about to order stuff from Susquehanna motor sports for this. They have nice 40 amp relays for this there. I have the parts for the headlight system already.
The schematic will speed it up some.
Again thanks.
Am I done yet?
Holy Moly, I am done.....
1969 1414X Wag,
71 project J truck FOR SALE
1970 Wagoneer Not Sadie
1983 FJ60 wagon
CJ-5's
Old 02-18-2018, 10:49 AM
Pillow Pillow is offline
Thanks Curly for posting the link! Def on my to-d or to-buy list depending.
1983 Cherokee Pioneer - in progress LS 5.3 w LS9 cam, NP208, & SM465
1968 J2000 Gladiator truck
1973 J4000 truck (organ donor for Cherokee & J2000)
1971 C-10 w 5.3 LS swap
1979 Porsche 911SC
Daily: 2007 Cadillac DTS
Old 08-25-2018, 04:43 PM
turtlehead's Avatar
turtlehead turtlehead is offline
Hey all!
I installed my harness and never got around to actually plugging a window motor into it.
Finally installed my original window motor - it kinda worked slowly for 5-10 seconds then died.
I just assumed the OLD motor was had - couldn't ever get it to move again.
So, I bought a new/refurbished motor, installed it, powered it on, same thing... ran REALLY SLOW/weak (without the window installed, just on the arms) and within 5-10 seconds it died. I removed it from the bracket/arms/gears - plugged it in and tried to run it without any of that stuff - and the motor wouldn't respond at all.
I have a feeling something is wrong with the wiring and it's frying the electric motor.
Any suggestions/ideas??
Here's a photo of the harness/wiring installed without the motor:
I installed the two red wires in terminals 1 and 2 opposite of the blue wires - I'm 99% sure that's correct, but also wondering if that's where I went wrong?
Old 08-26-2018, 09:07 AM
What motor are you using the early one, or the later style?
I ask because the early ones have a dedicated ground, the motor polarity is on separate wires. Meaning one wire is up and the other is down...neither is connected to ground!
The newer motors work by reversing polarity on two wires, and do not have a dedicated ground.
If you have it wired/setup for the newer motor, and you're using the older motor it will not work and you'll likely toast the motor.
Old 08-26-2018, 02:33 PM
turtlehead's Avatar
I'm not positive on the motor... the shop gave me one that is meant for a 72 Wagoneer Tailgate window.
But... it could be wrong?
It's a 2 wire motor - I believe some were 3 wires?
But... are you saying that even with 2 wires, it may still matter which wire goes to which post?
1972 Wagoneer
some really weird previous owner mods
it's an automatic now... boooooo
it's got a 1967 buick 340 - blah
and other weird things I'm working on
Old 08-26-2018, 02:51 PM
On the early motors only one wire/connection @ time gets 12v+
They do NOT get negative on other wire.
One wire/side is up the other wire/side is down.
The late model motors one wire gets 12v+ and other gets ground.
Reversing the polarity makes the motor go opposite direction.
Old 08-26-2018, 02:56 PM
turtlehead's Avatar
You rock...
So, I am a total noob on this stuff...
How would I go about testing the motor to see what is correct?
And, how do I compare that against the wiring in this harness?
Thanks!
1972 Wagoneer
Old 08-26-2018, 03:37 PM
post pic motor? showing wire connection terminals.
Old 08-26-2018, 03:55 PM
SJTD SJTD is offline
Early motors are three wire, with one wire permanently grounded, no?
Should be obvious which he has.
Sic friatur crustulum
Old 08-26-2018, 04:41 PM
turtlehead's Avatar
just realized the photo I have is of the original motor, I'm waiting for the replacement from the store. Should have it by tomorrow.
1972 Wagoneer
Old 08-26-2018, 04:43 PM
In your post on the other site I speculated that the blues went to the safety switch. I now think that's incorrect.
After looking at a relay and that close up picher I think the blues go to relay pins 30 which would be the motor leads. Either the two on a two wire motor or the up and down on a three wire.
Gonna have to study the pics more. To try and understand what's going on with your motor.
Also, where does the safety switch connect? Maybe the connector in the red wire? Looks like it feeds the switches. Unmate it and connect to the switch in series if you have it; leave the connector mated as is if you don't?
Old 08-26-2018, 04:45 PM
Is your original three wire or two?
Old 08-26-2018, 05:27 PM
turtlehead's Avatar
My understanding when installing this was the blue wires were what I needed to send out to the window motor to power it - and that it didn't matter which wire went to which terminal.
I think Serehill had this whole thing setup as he described that if "up" went down, you could just switch the two wires from one terminal to the other.
this image shows the two red wires that I understand run to the safety switch - serehill in his directions says you don't have to use the safety switch and you can leave these two wires like this. (again, I could be misunderstanding)
My motor - both original and replacement are two wire motors.
1972 Wagoneer
Old 08-28-2018, 09:12 AM
I should've thought of this before. Do you have a meter?
Hook it up to the two motor leads on the terminal strip and see what you get. Should be 12V in one direction and -12V in the other.
It's not unheard of to get a bad rebuilt motor.
Old 08-28-2018, 09:49 AM
You need to post a pic of the motor you're using, and verify it is the correct one. I question if an aftermarket rebuilt is actually correct?
Many vendors/manufacturers incorrectly assume all years that parts are same.
As said earlier the new/late ones work differently. If not wired correctly they won't work, and you can damage the early one using the later style wiring setup.
Old 08-29-2018, 10:46 PM
Are the more than two versions; those being the two wire and the earlier three wire?
Old 09-03-2018, 10:55 PM
turtlehead's Avatar
1972 Wagoneer
Electric Tailgate Window Troubleshooting jbentley General FSJ Tech 53 04-28-2020 07:35 AM
Durango rear wiper motor install acct21 Electrical 3 07-26-2017 12:09 PM
Tailgate stock wiring harness cma FSJ-PRIS 15 05-20-2015 01:23 PM
