I have installed my tfi upgrade and now i need to gap my plugs but i don't remember what to gap them to anyone out there know? thanks in advance
tfi upgrade sparkplug gap?
I'm gonna hijack on this thread...I asked a question on the ford f150 forum pertaining to this upgrade...I did it on my wag, I was wondering if I can use the same coil on a '79 f150 with a Jasper 6.6l 400...I mean-we use all the parts from a '79ish truckwith a 93ish coil and wires... theoreticly it sounds like it should work...right?? the thing I am hesitant about is the gap...I think the ford is already at .44...would I need to increase that??85 Grand Wag:360 *219k* 4bl 1406, tfi upgrade, rear 3" blocks,front(get this) "rear"shackle drop kit (net 5" lift) , 265.70.16 bfg at's,flomaster40,boobie grille swap
Originally posted by shaolinsifuI'm gonna hijack on this thread...I asked a question on the ford f150 forum pertaining to this upgrade...I did it on my wag, I was wondering if I can use the same coil on a '79 f150 with a Jasper 6.6l 400...I mean-we use all the parts from a '79ish truckwith a 93ish coil and wires... theoreticly it sounds like it should work...right?? the thing I am hesitant about is the gap...I think the ford is already at .44...would I need to increase that??
they are called Bosch Platinum Plus 2...they are pre-gapped from Bosch and would be difficult to accurately re-gap they are designed for stock gap replacement but deliver a bigger spark to more efficiently burn la la la I don't mean to sound like a commercial...If you just did the tfi upgrade, pick up some single electrode plugs and gap 'em to .44,/.45 to achieve the result of the upgrade you are looking for... I ran champion standard plugs when I did mine, but while I am canging out the carb and cam and all that jazz,I will drop in a set of Bosch platinum plus plugs (single electrode) I have always had good luck with them85 Grand Wag:360 *219k* 4bl 1406, tfi upgrade, rear 3" blocks,front(get this) "rear"shackle drop kit (net 5" lift) , 265.70.16 bfg at's,flomaster40,boobie grille swap
