Yeah brother..what the hippie said...if it's a straight Chief it's worth your time and effort.
Freeze plug! Here's what I did when the rubber replacement plug shot out of the '77 J truck the day I was leaving for ECI last year. Not that you would want to follow my lead but...
I drilled a hole in the inner fender and drove a new one in the block with a socket on an extension. Then I drove the thing 4 hrs to URE, wheeled it, broke it, fixed it and drove it the 4 hrs home again. No worries. A new plug isn't even 12 bucks. The kit is and it's a squishable rubber gadget that will likely fail once the engine gets good and hot.
TH400 rebuild kits are around $100. Many a local shop would do it for a couple hundred labor. Shop around you may find it's not as expensive as you thought. I rebuilt one the week before ECI '08. It was my first attempt at an automatic rebuild and I will never pay anyone to do it again. Without having the few specialty tools I had a few troubles, but once I figured out how to assemble the thing it was rather easy.
I say keep it and fix it.
