Old 09-25-2019, 08:30 PM
GWNashville's Avatar
Re: Holley Sniper EFI
Hey Guys
I need a little help. I installed a EFI Sniper Hyperspark system and it runs great for about 25 minutes and then it cuts off like someone turned the key off. The fuel pressure is at 59 lbs, I have checked grounds three times. I talked to Holley they thought it might be the coil because it gets really hot. They sent a new one same result. Has anyone had this issue and if so what did you do to fix it. Greatly appreciated. Richard.
Richard
GWNashville
1989 Grand Wagoneer 360 c.i.
727 Transmission
Old 09-30-2019, 12:22 AM
acct21's Avatar
acct21 acct21 is offline
Tell us a little more about your setup. Stock/OEM ignition, or the Holley CDI? What kind of fuel pump are you running (in-tank, frame mount, surge tank)?
Old 09-30-2019, 11:29 AM
babywag babywag is online now
best bet is either holley tech support forum
or call them.
only a few folks using it here.
that said usually if it just shuts off it's electrical.
if it doesn't fire right back up likely bad component.
if it does fire right back up probably a bad connection somewhere.
since it's time/heat related odds say bad component.
Holley EFI W/ Holley Hyperspark Distributor? BamaWagoneer Fuel Injection 15 09-26-2019 08:44 AM
Holley sniper EFI 727 kickdown J10 Bob Fuel Injection 9 07-06-2019 06:51 PM
Holley Sniper EFI Darwin1876 Fuel Injection 33 11-06-2018 11:17 AM
Holley Sniper EFI 2BBL experience DattMtn General FSJ Tech 2 09-19-2018 04:29 PM
Temp Sensor location for Holley Sniper EFI Blinkinlights Fuel Injection 2 04-22-2017 05:30 PM
