  #61
Old 11-10-2016, 03:41 PM
SOLSAKS's Avatar
SOLSAKS SOLSAKS is offline
carpet crease
an industrial steamer will get out the crease
once i had a headliner stored in a box for 2 years
for a 1969 charger,
it had been folded into a 12x12 square
the steamer got it out like magic.
my friend who works at a furniture manufacturer
got it from work.
they use it to remove creases in upholstery fabric
( be careful, those machines will take the flesh right off the bone ! )
Old 11-13-2016, 06:36 PM
medinajim2000's Avatar
medinajim2000 medinajim2000 is offline
This weekend I got the center armrest console completed except for the cover plate. Finished up the overhead console. Installed the front area headliner.
Now I've got rear air and two additional power outlets.
https://www.facebook.com/ClassicGrandWagoneers/
89 GW (Black Cherry) - In Resto
85 GW (Gold) - In Resto
89 GW (Gray) - MINE!
86 GW (Garnet) - In Resto
84 GW (Bronze) - In Resto
75 Cherokee S (Blue)(Gone)
89 GW (Gray)(Gone)
87 GW (White)(Gone)
86 GW (Blue)(Gone)
88 GW (Gray)(Gone)
89 GW (Gold)(Gone)
89 GW (Gray)(Gone)
Old 11-14-2016, 07:15 AM
How u get air to it?
Separate or piped in?
Seems it would fit into dash if you did some cutting in front and tied it into vents.
Looks,like it belongs other than that.
Old 11-14-2016, 08:36 AM
It's ducted in from under the vents.
89 GW (Gray)(Gone)
87 GW (White)(Gone)
86 GW (Blue)(Gone)
88 GW (Gray)(Gone)
89 GW (Gold)(Gone)
89 GW (Gray)(Gone)
Old 11-14-2016, 09:43 AM
HoosierWoody's Avatar
HoosierWoody HoosierWoody is offline
Noob!
It looks great. That's a lot of work!
Any chance you remember where and what the matching burgundy paint came from? I'm trying to get as close as I can with not much luck. Thanks.
Working on my first one!
Making progress on 1987 Woody.
Old 11-15-2016, 09:55 PM
Sorry. I've had a lot going on. I used Color Bond LVP Leather, Vinyl and Plastic Refinisher. #648 Ford King Ranch Red.
89 GW (Gray)(Gone)
87 GW (White)(Gone)
86 GW (Blue)(Gone)
88 GW (Gray)(Gone)
89 GW (Gold)(Gone)
89 GW (Gray)(Gone)
Old 11-23-2016, 08:43 AM
SOLSAKS's Avatar
console
man, that console looks great.
nice work.
you are going to have one nice wagoneer.
Old 11-29-2016, 09:11 AM
eribbs's Avatar
eribbs eribbs is offline
Noob!
Out of curiosity, what method did you use to polish the bumpers? I am about to do mine, and was wondering if you had any tips - yours look great. thanks!
Old 03-14-2017, 09:15 AM
Took a break from Halloween until now, when my wife decided to go nuts and file for divorce. Just got back into this, and installed the wood grain this weekend.
89 GW (Gray)(Gone)
87 GW (White)(Gone)
86 GW (Blue)(Gone)
88 GW (Gray)(Gone)
89 GW (Gold)(Gone)
89 GW (Gray)(Gone)
Old 03-14-2017, 09:23 AM
We used the Marine Teak vinyl from Team Grand Wagoneer. I now know that BJ's also carries this same vinyl.
After removing the wood trim using a heat gun, we cleaned the panels with denatured alcohol, then wiped with a micro fiber rag to delint it. We positioned the decal where we wanted it, then used masking tape along the top edge to create a hinge. Then we started at the top, pulling about an inch of the paper from the backside of the decal, working our way down with a squeegee (included with the kit). Work slow, starting in the center and working your way out. We didn't get any air bubbles.
89 GW (Gray)(Gone)
87 GW (White)(Gone)
86 GW (Blue)(Gone)
88 GW (Gray)(Gone)
89 GW (Gold)(Gone)
89 GW (Gray)(Gone)
Old 03-14-2017, 12:27 PM
for a 1969 charger,
got it from work.
Thanks for the tip on the steamer. Worked like a charm.
89 GW (Gray)(Gone)
87 GW (White)(Gone)
86 GW (Blue)(Gone)
88 GW (Gray)(Gone)
89 GW (Gold)(Gone)
89 GW (Gray)(Gone)
Old 03-24-2017, 02:01 PM
Finally got around to finishing up the center console. I used ABS plastic, heated it with a heat gun, cut it with a carpet knife. Then used the same spray paint I used on the console to paint and trimmed out with door edge molding. Double sided velcro on the back to attach to the console.
89 GW (Gray)(Gone)
87 GW (White)(Gone)
86 GW (Blue)(Gone)
88 GW (Gray)(Gone)
89 GW (Gold)(Gone)
89 GW (Gray)(Gone)
Old 03-24-2017, 02:02 PM
Headliner reinstalled.
89 GW (Gray)(Gone)
87 GW (White)(Gone)
86 GW (Blue)(Gone)
88 GW (Gray)(Gone)
89 GW (Gold)(Gone)
89 GW (Gray)(Gone)
Old 03-24-2017, 02:04 PM
Cargo strips cleaned, polished and installed. Seatbelts and back seat put back in. All that's left now is the back door window motors, locks and glides on the back glass. Clean up and she's done. On to the next one.
89 GW (Gray)(Gone)
87 GW (White)(Gone)
86 GW (Blue)(Gone)
88 GW (Gray)(Gone)
89 GW (Gold)(Gone)
89 GW (Gray)(Gone)
Old 06-01-2017, 07:09 AM
Almost done.
Just a few little odds and ends left to do.
89 GW (Gray)(Gone)
87 GW (White)(Gone)
86 GW (Blue)(Gone)
88 GW (Gray)(Gone)
89 GW (Gold)(Gone)
89 GW (Gray)(Gone)
Old 06-01-2017, 11:13 AM
SOLSAKS's Avatar
fantastic job medina jim
VERY NICE WAGONEER !!!
dave in NC
Old 06-02-2017, 09:09 AM
Cherokeeowner's Avatar
Cherokeeowner Cherokeeowner is offline
Originally Posted by medinajim2000
Thought I'd test fit the new console. This lets me have rear air, cupholders front and back, power devices and a place to put the heated seat controls.
I thought I'd cover the armrest pad and lower section of the sides with a marine grade vinyl I found that really almost matches the leather. Paint the top portion either burgundy or black, and laminate a cover (to fill the space just under the original dash A/C vents) with a woodgrain that closely matches the interior woodgrain. And try to throw in some nice chrome trim.
All of you picture links are broken on my end.
"Proud to be prissy."
1988 Grand Wagoneer
1986 Grand Wagoneer
Old 06-02-2017, 11:44 AM
Hum. They work on mine. They weren't this morning for some reason, but they are now.
89 GW (Gray)(Gone)
87 GW (White)(Gone)
86 GW (Blue)(Gone)
88 GW (Gray)(Gone)
89 GW (Gold)(Gone)
89 GW (Gray)(Gone)
Old 07-06-2017, 09:12 AM
Stoopit Fotobucket.
89 GW (Gray)(Gone)
87 GW (White)(Gone)
86 GW (Blue)(Gone)
88 GW (Gray)(Gone)
89 GW (Gold)(Gone)
89 GW (Gray)(Gone)
Old 07-06-2017, 09:13 AM
Finally got around to fixing the woodgrain trim that I wasn't happy with. It looks so much better now.
89 GW (Gray)(Gone)
87 GW (White)(Gone)
86 GW (Blue)(Gone)
88 GW (Gray)(Gone)
89 GW (Gold)(Gone)
89 GW (Gray)(Gone)
Gettin back in the game Jameshallmodel General FSJ Discussion 8 02-03-2011 08:42 AM
Waggy back window woes smogdredd General FSJ Discussion 14 12-13-2010 12:47 PM
Waggy broke my back!!!! Literally!!! banjoguy General FSJ Discussion 23 10-22-2010 09:52 AM
Back in the FSJ game!!! rock&roll General FSJ Discussion 8 12-23-2007 07:01 AM
Back Seat - Baby Seats? Tanker (MWJT) General FSJ Discussion 20 12-06-2007 01:55 PM
