Another newb question: A search returns SO MANY suggestions that I've got nothin'. I wish people would respond with what the ultimate fix was.
When it's cold it runs great. I can fire it right up in the morning and immediately drive away nice and strong.
As it starts warming up it begins to stumble and choke. Occasionally it will clear something out and lurch back to full speed for a few minutes, then return to stumbling. Sometimes it backfires through the tailpipe when it begins to stumble. Sometimes (not all the time) the electrical will dim during the stumble.
Once it's fully warm it will start stumbling so bad that it will eventually cease to run under it's own power. It eventually dies and then it won't restart until I let it cool off for half an hour.
The temp gauge never reads any warmer than the far left bar; typical for this rig.
The big things that happened recently and which I suspect is the carb was rebuilt and the cat/muffler were replaced. Before rebuilding the car the cat was so restricted that it ran very poorly and had horrible gas mileage.
So brand new Power Valve, Accel Pump/Everything in the carb. Exhaust is finally flowing freely. Brand new cap and rotor, plugs and wires. The choke plates are operating as I would expect; closed 1/8" when cold, wide open when warm.
The flapper thing in the tailpipe works. The doors in the air filter housing open properly when warm.
There IS a chance that there was one backfire that could have ruined my brand new Power Valve. But there's no fuel in the PV's vacuum line and the line has vacuum.
Could the Power Valve run great when cold and horribly when warm? I seem to think that if the Power Valve was blown that it would always run horribly. Right now when it's cold it actually runs better than it ever has: TONS of power and as smooth as glass. I can actually make it to work before it warms up and stumbles if I don't hit too many red lights (3.7 miles hehe).
The choke plate is fully open when warm.
I don't have new aluminum headers that are boiling off the fuel in the bowl. (heh read that in a post, I'm trying everything )
Um; I'm still trying to figure out what the distributor pick up spring is (someone said to bend it).
The carb linkage is clean and lubricated and is functioning properly.
I haven't yet ruled out super heated fuel (still trying to figure out how).
Jay I have experienced a faulty ignition module, this doesn't feel like it. It won't just cut off; it instead seems to bog dog to the point that it just won't combust. When I had a bad ign module it would just suddenly go from running great to "bink", nothing.
I don't know how to check for slop in the timing chain; and I don't know how to check timing. I looked for timing marks on the dizzy/block and couldn't find anything. With a clean carb and freely flowing exhaust could the timing now be off?
[ January 29, 2006, 08:24 PM: Message edited by: Tahnka ]
