Very impressive.
Another freebie!!!! Update
Originally posted by MikelVery impressive.Jeff
'43 cj2a
'51 Willys p/u
'51 Willys Parkway Conversion
'68 Panel Delivery
'74 CJ5
'75 J-20 Wrecker
'75 J-20 Cummins service bed
'77 J-10 p/u
'79 Cherokee
'88 Grand Wagoneer
'98 Grand Cherokee
Originally posted by SJTDYeah. I just checked my valves. What a pain.
I was looking back a few pages and noticed something that didn't register with me before. Why did you mess with the mounts on the frame? Did you move the motor forward?Jeff
'43 cj2a
'51 Willys p/u
'68 Panel Delivery
'74 CJ5
'75 J-20 Wrecker
'77 J-10 p/u
'79 Cherokee
'88 Grand Wagoneer
'98 Grand Cherokee
Ok, got a little more done, and a big step forward today. Mounted cruise control module under the fender, lengthened the trigger wires and mounted the intake heater solonoids. I then found out that the clutch wasn't giving enough throw to engage, so I raised the peddles up 1" and bumped the starter and it turned over. :evil:
Playing with the door harness making sure that was not my problem, I hit the key fob and the locks moved. That means I get keyless entry... 8-)
'43 cj2a
'51 Willys p/u
'68 Panel Delivery
'74 CJ5
'75 J-20 Wrecker
'77 J-10 p/u
'79 Cherokee
'88 Grand Wagoneer
'98 Grand Cherokee
IT RUNS, IT RUNS...
Started with an oil change, fuel into tank, bled lines and got it running. I then used the dodge plastic inner fenders to keep the engine somewhat clean, mounted fenders, valance, grill and hood. I was alone today, so no video yet, but a couple new pics. I need to find a pair of M715 hold downs.
'43 cj2a
'51 Willys p/u
'68 Panel Delivery
'74 CJ5
'75 J-20 Wrecker
'77 J-10 p/u
'79 Cherokee
'88 Grand Wagoneer
'98 Grand Cherokee
Got to spend another day buttoning up the details. Brakes are bled, great pedal. Coolant lines attached, filled with coolant, no puddles. Moved inside and started moving wires around and got them tucked up out of the way. Mounted drivers seat. Moved underneath and looked into the t-case shifter. Mounted drive shaft. Pic is deceiving, there's about an inch between the tank and shaft.
I did find hood latches on eBay, in black, for $21. They are on the way.
'43 cj2a
'51 Willys p/u
'68 Panel Delivery
'74 CJ5
'75 J-20 Wrecker
'77 J-10 p/u
'79 Cherokee
'88 Grand Wagoneer
'98 Grand Cherokee
Got more done, bed off old frame and set on new. I took pics before I settled it into place, but it's squared up and ready to bolt. It squatted about 6" when I set the bed on...
'43 cj2a
'51 Willys p/u
'68 Panel Delivery
'74 CJ5
'75 J-20 Wrecker
'77 J-10 p/u
'79 Cherokee
'88 Grand Wagoneer
'98 Grand Cherokee
Ive got my cousin looking for a set of 4" lowering coils for the front.
Damn, I can't seem to focus on anything else...Jeff
'43 cj2a
'51 Willys p/u
'68 Panel Delivery
'74 CJ5
'75 J-20 Wrecker
'77 J-10 p/u
'79 Cherokee
'88 Grand Wagoneer
'98 Grand Cherokee
Originally posted by jaberIve got my cousin looking for a set of 4" lowering coils for the front.
Damn, I can't seem to focus on anything else...1969 M715 6x6
1963 J300 Swivel frame
Good thought, I'll keep an eye on it when I get them.
Got the hold downs on, and started wiring front lights.
'43 cj2a
'51 Willys p/u
'68 Panel Delivery
'74 CJ5
'75 J-20 Wrecker
'77 J-10 p/u
'79 Cherokee
'88 Grand Wagoneer
'98 Grand Cherokee
