Old 12-08-2019, 02:27 PM
Cookingguy Cookingguy is offline
Qudratrack question
Hi all,
So I am doing new seals on my transfer case. Well I noticed alot of play in the rear output shaft. Is this normal?
Old 12-08-2019, 08:24 PM
What do you mean by play? A few degrees of twisting motion? Up and down/side to side? Or in and out?
A little twisting is ok but probably means your chain is slacked/worn. Up/down is the ball bearing inside and is bad. In and out, not sure.
Old 12-20-2019, 04:36 PM
I have several guesses of which none probably apply.
It is very likely the chain is not broken yet though...
Old 12-20-2019, 05:35 PM
That looks very familiar!!
Old 12-20-2019, 07:09 PM
rws31's Avatar
rws31 rws31 is offline
OUCH!
89 GW, 454, 700R4, 241C, 411's with posi's, 9" rearend, 2500 stall, lifted, and lots more to do.
1988 Ramcharger
1999 International 4700 Crew Cab 4X4, custom step side bed
2003 Durango 4x4
1982 CJ7 4 banger
2008 MB E320 Bluetec
Another A/C Question: York or Sanden The PIG Smith General FSJ Tech 27 07-03-2018 04:29 PM
Axle Question Jjkage84 General FSJ Tech 4 05-12-2014 11:22 PM
1 PS question, 1 eletrical question SamW General FSJ Tech 2 01-15-2011 12:31 PM
Quick 85 Grand Wagoneer Question WagoneerMan General FSJ Tech 3 01-31-2010 11:06 PM
