on a late Grand Wagoneer, I know when you go with a 4" spring lift you have more to do than simply bolt on 4 new springs and go with it, but what all those "extra" things are...I dont know.
The ones Im aware of are longer brake hoses between the axels and chassis.
Longer shocks, front and rear.
Dropped pitman arm.
What else?
Also, is it any more involved to install a 6" spring only lift instead of a 4" lift?
Also, what can you do to the things the springs mount to front and rear if your originals look kinda rough? Are there longer versions for the front and rear to get a little more lift?
Dropped pitman arm.
What else?
