Old 04-12-2011, 07:48 PM
Tin Medic's Avatar
Tin Medic Tin Medic is offline
Loose (lug)Nut(s)
Tint Removal
Does anyone know of a way to remove what I believe is the factory tint from an 89 GW? The tint has been scratched and nicked and anything else you can think of and I need to replace it. Thanks.
Sons Waggy - 89 GW 360/727/208, 30x9.5x15 Destination M/Ts, Warn Lock Out Hubs, Razor Grill
Tramp - 85 CJ-7 Renegade FI 258/T5/D300, D30 w/ARB Air Locker, AMC 20 w/Posi Unit, 33x12.5x15 Goodyear MT-R's, Hella E-Code lights, VIAIR OBA System, Warn 8000lb Winch
Old 04-12-2011, 08:06 PM
Michael_King024's Avatar
Michael_King024 Michael_King024 is offline
flat razor and warm soapy water
Big Mike
83 wag limited-360-
89 G.wag -360-
"10-4 rubber duck"
"In GOD we trust..all others pay cash"
-mat. 21:42-
Old 04-12-2011, 09:09 PM
Chrome's Avatar
Chrome Chrome is offline
Ph.D in Redneckology
Factory tint is made into the glass. Aftermarket is applied to the glass. If it peels thens it's aftermarket. Here's a "How to" I posted on tinting windows. http://www.ifsja.org/forums/vb/showt...highlight=tint
X2 on the razor and soapy water.
..,=====,o00o
//__l_l_,\____\,__
l_---\_l__l---0
lllllll0
_(o)_)__(o)_)--o-)_)___
Old 04-12-2011, 10:07 PM
Tin Medic's Avatar
Loose (lug)Nut(s)
This is definately aftermarket tint.
Old 04-12-2011, 10:22 PM
lunchbox1671's Avatar
lunchbox1671 lunchbox1671 is offline
Be careful on your rear window, if you have a defroster. You can scratch the material off the glass...
1979 Jeep Cherokee Chief Sport 4 door N/T.
-AMC 360 with RV cam
-T-15A, Dana 20
-Dana 44's, 3.54's,
-32x11.50r16's
Old 04-13-2011, 05:02 AM
Daddio's Avatar
Daddio Daddio is offline
I found a tip to remove tint online and it worked great for me. Take some plastic garbage bags and cut them to fit your the inside of your windows. Use windex with ammonia and spay the tint. Next put the plastic bag on top of the windex and let it sit for a at least 15 minutes. If it dries out, reapply some more windex.
What happens is the tint adhesive softens and it comes off much easier. Most of my tint just peeled off.
'88 Grand Wagoneer, towing package, 360 .030, Holley Street Dominator intake, Holley Projection, rv cam, double roller timing chain, HEI, CS144, oil pump mid plate, Thorley Headers, BJ's 3" exhaust, and more...
http://www.youtube.com/watch?v=xWWCj...layer_embedded
Old 04-13-2011, 08:47 AM
Jeepster4ever Jeepster4ever is offline
Wink It's true
I use this method all the time if the tint on a heated window doesn't want to completely pull off or you can also try heating up a square foot at a time with a heat gun and then gently pulling at a chunk of the tinting to see if it will come off that way.
For all the other windows use the saftey blades but makes sure you keep getting new ones for at least every window as they can scratch the glass if there sharp edge gets bent or nicked.
Old 04-13-2011, 10:47 AM
for me windex and other glass cleaners have always made the adhesive harder to get off...its like it cryatalizes it almost...i will pull the tint off..and normally a layer of adhesive remains on the glass...then i spray it with the soapy water and let it sit for a minute....usually the adhesive will soften enough that you dont actually need a razor at all...
you should use soapy water instead of windex when applying tint also...like i said windex will crystalize the adhesive and drastically shortens the working time needed to form and squeege the film and remove the bubbles
the only time ive ever used a heat gun is to apply tint film and that is only when i needed to "mold" the film for curves in the glass...and even then a little goes a long way
Big Mike
83 wag limited-360-
89 G.wag -360-
"10-4 rubber duck"
-mat. 21:42-
Old 04-13-2011, 11:38 AM
3rdelement's Avatar
3rdelement 3rdelement is offline
goto walmart, they have a good tint removal kit. i used it for the liquid and the razor holder. after you get off as much as you can, then go over it with goo gone and then with windex.
Richard Ricketts
build thread: click HERE
1985 Jeep Grand Wagoneer {woodless}-Edelbrock 1406 carb, Edelbrock Sp2p Intake, Hella ecode headlights, bixenon HID 5000k headlights, mb quart 6.5" component speakers f&r, alpine cde-100 deck, final edition grill, Hella 550 fog lights, 1991 window regulators, cs144, aluminum coolant&washer tanks
rear window tint with defroster RALVES General FSJ Discussion 8 12-24-2010 12:05 PM
CS144 pulley removal - tapered collar type dakatl General FSJ Tech 6 12-13-2010 05:46 AM
Easy Window Tint Removal loganvilledude General FSJ Tech 5 03-15-2009 09:17 AM
Window Tint Removal dnixon General FSJ Tech 4 08-17-2002 02:06 PM
Window tint question. derf General FSJ Tech 11 07-23-2001 10:40 AM
