Old 08-12-2014, 06:21 AM
AdamJay1979's Avatar
AdamJay1979 AdamJay1979 is offline
Engine swap vs. fuel injection
Have been considering fuel injecting my I6 258... a buddy suggested this week just putting a different modern engine in instead... intriguing as the parts are $1300 for the injection and a decent engine is in the same ball park... thoughts, doubts, concerns???? words of wisdom or warning?????
Adam Jay
1979 Cherokee Chief I6 4.2L 258
Old 08-12-2014, 10:28 AM
Get a 4.0L with the underhood EFI wiring ('91 to '95 XJ or YJ) and AW4 for auto (not 42RE which is a turd) or AX15 for std. I like the NP242 tcase which is like the NP229, but no viscous coupler. That way there is no $350 motor mount adapters (use the 4.0L ones) and you swap in Hydroboost to clear the intake (improving brakes at the same time)
You will need to make a trans crossbar, but you would have to do that anyways with a conversion.
PS: My EFI was $200 for all the parts from the junkyard locally. 4.0L core for the head/intake/injectors, wiring harness (auto controller was under the dash) I also got a '91 XJ for parts for $500 to get the parts for my Eagle wagon.
Big Block Ford 460 Wagoneer Build Thread jonygeorge General FSJ Tech 37 06-25-2012 08:37 PM
Engine Build-Up: TBI Fuel Delivery (with pics) chr1s Fuel Injection 11 01-15-2009 08:23 PM
Engine noise, 4.0 swap???? Mex in the city General FSJ Tech 5 11-24-2008 04:00 PM
Engine Swap newer w/ fuel injection for old YJ Daryl Dalton Fuel Injection 3 09-09-2004 03:09 AM
Help / Vapor Lock Issue key General FSJ Tech 9 04-09-2004 10:54 AM
