Old 02-21-2013, 09:24 AM
1979cherokee's Avatar
1979cherokee 1979cherokee is offline
GM TBI
My carb on my cherokee is junk im thinking about going to TBI. How hard is it going to be to install the system in my cherokee?
BIG RED 31inch Mickey Thompsons Baja MTZ, Rustys 4 inch full spring lift, 1973 AMC 360 Chevy TBI, edelbrock performer intake,.030 over, crane cam, dubble roller timing set,TH400, BW1339, Dana 44 front and rear, Bj's offroad prerunner bumper. Full size for life with the exception of GM product and no Fords.
Old 02-21-2013, 09:36 AM
Depends.
Are you going to buy a ready to go package, or DIY?
If you can turn a wrench, and have some tools knowledge it's pretty easy.
DIY route, you'll need some additional stuff to tune it.
Old 02-21-2013, 09:45 AM
im going DIY.
Old 02-21-2013, 11:55 AM
FSJ Guy FSJ Guy is offline
Originally Posted by 1979cherokee
im going DIY.
READ. Read. Read.
And read some more.
It will make your brain hurt if you are new to TBI and/or electronics, but it is well worth the investment of the time.
It's not particularly tough to understand, but it is different than carbs and such. OTOH, it is also similar, in that it is designed to feed an Otto cycle engine. Thus, there are the electronic versions of a choke, fast idle and other things.
I would recommend a setup that includes timing control if your local emissions laws allow it.
Welcome!
Ethan Brady
www.bigscaryjeep.com
Old 02-21-2013, 06:36 PM
i started reading about the system, i have a friend who has a 87 chevy with the tbi system so i can look at that truck to see how it works.
Old 02-21-2013, 09:06 PM
How smart is your friend?
Think he or she would notice if you swiped some parts?
Ethan Brady
Old 02-21-2013, 10:33 PM
jeepfan93's Avatar
jeepfan93 jeepfan93 is offline
going this route myself. Binderplanet.com read read read
Jeeps are Jeeps, keep Jeepin
>It's not about the ten hour drive to get the rust bucket jeep, it's about where your your going when it's done
87GW 99 Durango 5.2 drivetrain, SOA 35in Falken Wildpeak. MT rims
1997 Ram 1500 5.2 33in Falken Rocky Mounts for haulin
Old 02-21-2013, 11:14 PM
Start with the "start here" thread. It will open a whole page of FAQ's.
It starts at the top with the parts required then goes to the wiring and then lots of examples of different sytem installs including a complete step by step.
Bill USN-1
Hamilton Fuel Injection
Old 02-22-2013, 07:39 AM
no im not going to swap parts. Im already reading everything i can about TBI.
Old 02-25-2013, 03:20 PM
how do i adapt the throttle body to the intake?
Old 02-25-2013, 06:05 PM
jeepfan93's Avatar
http://www.summitracing.com/parts/trd-2211
Now go back and read the Binderplanet stuff. It's all in there. Stock 2 bbl intake? I would seriously upgrade to an aftermarket 4BBL
Old 02-26-2013, 11:59 AM
Really? An expensive 4V aftermarket intake under a 2V throttle body? What good will that do?
Old 02-26-2013, 01:09 PM
You'll gain 10 ponies just from the weight difference!
I put a Performer intake under my 2 barrel TBI unit, too. <shrug>
Ethan Brady
Old 02-26-2013, 02:36 PM
ok, thanks i went to binder planet and read and read and read and i couldent find how to adapt the throttle body.
Old 02-26-2013, 03:02 PM
Really...
http://www.binderplanet.com/forums/s...ad.php?t=47254
Scroll down to "TBI" section and look for the below link
"What Throttle Body adapter do I need?"
Old 02-26-2013, 03:04 PM
Under the header TBI is the 2nd thread that says what adapter do i need.
Bill USN-1
Howell and GM Based TBI FAQs and other forum links FSJ Guy Fuel Injection 2 02-27-2012 06:27 PM
TBI throttle cable?? JeepsAndGuns General FSJ Discussion 17 02-17-2011 06:06 PM
D.I.Y Throttle body injection write up (With pics!!!!) and this is no hoax Wagoneerlover Engine 28 06-25-2007 12:43 PM
D.I.Y Throttle body injection write up (With pics!!!!) and this is no haox Wagoneerlover Fuel Injection 28 06-25-2007 12:43 PM
