Have a look at most modern engines that were designed around port injection. You'll see that the injectors are placed such that they shoot directly onto and pretty much perpendicular to the intake valve head. Short of designing new AMC V8 heads, you'll miss this advantage with any sort of add-on MPFI. Another advantage of port injection is that it allows a "dry" manifold, rather than mixing fuel at the manifold inlet where it can separate in certain scenarios (like rapid throttle opening or very high velocity). So, as tgreese said, it can allow somewhat finer mixture control compared to throttle-body injection, but on an add-on setup, that difference is vanishingly small.
There are other reasons why some people choose multi-port, including more modern, more reliable pieces, sometimes a little better tuneability, and the nth degree of power potential at high revs. If I were building a 6,000 RPM 401 I'd sure try to cobble up a multi-port system. But for a Jeep doing typical Jeepish things, I think the GM TBI is 98% as good.
S.J.
S.J.
