I got a pretty good ways fabbing my new bumper
what did u do to your jeep this weekend
This is a sticky topic.
90 Wagoneer w/65 Wag.grille,Cj7 lights,360 AMC w/edelbrock perf.cam,lifters,timing chain,intake,carb,and,headers,custom SS exhaust w/magnaflow muffler,Black cherry pearl w/cordovan interior.Rusty's 4" lift w/KMC revolver bronze 17 x 9 wheels ,& Toyo MT 295-70-17 tires(33").http://s220.photobucket.com/albums/d...nd%20Wagoneer/
Originally posted by KenallNE 1 notice the rock and the tire.
Originally posted by fulsizjeepdrive it like I wanna drive it
1977 J-20, 4bbl AMC 360/t-18,33"s.
1976 CJ-5, Healthy AMC 360/t-18, 6" lift, 35"s.
1972 Javelin SST, mild AMC 360. Under cunstruction.
AMC ya!!
Alfano Performance
Kenosha, WI 53142
A little whine on the highway, to be expected. I wheeled them in Moab last month and go great on slick rock with 12lb air.Flint
Well, I got the front axle and springs out of the j20, and the springs off the axle. Then I started prepping the wag's axles. Torched off the springs, shocks, and driveshafts. Then pulled the axle shafts out to get the hubs/drums off. Got that done and drove the studs out to get rid of the drums. Just slid the hubs back on for now. Then we torched off the ubolts from the front 44 and pulled the calipers off so it'll roll. Now to get the wag in my possession and get it back together. Now for picture time.....
How she drove to her dismantling:
Brush guard and tires removed with stands under frame:
Something is missing:
The new Wag axles, HD44(GM) and 14bolt:
Changed the pics to links because they're huge.Where is my axle?
79 j20/84 GW GM Hybrid
We said Hi to it when we went to go pay his storage bill
We want to drive it, but he's waiting his turn in the garage.
Finally tackled the water pump leak on the 85.... and found a couple bolts missing under the non functional AC compressor.... and plenty of silicone.... I could not install new bolts back due to the silicon packed into the threads of the missing bolts -amazing, it never leaked- ... and clean all the grease that had built under the AC bracket... aaaaack.
So I had to pull the timing cover, the timing chain tested OK... when looking at the distributor... but when the cover was off.... a new chain was needed... and it must have been the OEM chain at 205K, the timing gears were OEM, still have the jeep part #... later I can post a pict of a good timing gear....
I decided not to reinstall the AC comp, the battery ground was now too short... upon reinstalling the PS belt, the vacuum advance nipple was touching the belt... I timed it before installing the belt and it ran fine... so quiet without the PS and the air pump..... so I had to reclock the distributor... and swaped #4 and 8 wires... so it ran like crap... with low vacuum manifold at 15" and backfiring until I rechecked everything... with all the hoses replaced there was only one loose one.... But the connector for the rear heater hose on the intake manifold is getting seriously rusted... the one with the 5 port vacuum switch....Last edited by letank; 06-04-2012, 12:42 PM.Michel
85 Gwag, 229 Kmiles. $250 FSJ test lab since 02, that refuses to give up but still leaks.
Originally posted by ShowngoI got a pretty good ways fabbing my new bumper
All I did this weekend is start the body work on my extra doors77 J20
09 Rubicon Unlimited
10 Challenger SRT 8 6 Speed
11 Grand Cherokee Overland
Wisconsin Speed and Performance
new windshield finnaly!!!!
Windshield before and after
full shot73 J-4000 "/Battillac\" 500 Caddy,400/QT w/low, 44 f&r[3,07\'s],35x12.5 BFGoodrich AT's,Auto Meter gauges,TCI trans.cooler,poly fuel tank,Flex-o-lite 7 blade,poly trans mounts,electric cooling fan,straight pipes loud and proud, Front disc conversion, 6" lift, Rancho RS5000 Shocks,Chrome Cragars
63 j-200 "green turd" 230 ohc 3 spd all stock
Originally posted by FSJ_DanielWindshield before and afterJeepasaurus (Wagonus Grandi quadropedus)
Finally got to the point of removing the bad trans and I prepped the new one for installation. Old on the left, newer (19k miles) on the right.
Project: 1979 Wagoneer 360, Turbo 400, Q-Track, and Dana 44's
Lovingly refereed to as the "The Wagon"...
Daily Driver: 2008 Jeep Commander Rocky Mountain Edition 4.7L, Q-Trac II
http://i285.photobucket.com/albums/ll58/jeepxk/DSC08388.jpg
Originally posted by Rich88Ain't getting a new windshield is one of the sweetest things.73 J-4000 "/Battillac\" 500 Caddy,400/QT w/low, 44 f&r[3,07\'s],35x12.5 BFGoodrich AT's,Auto Meter gauges,TCI trans.cooler,poly fuel tank,Flex-o-lite 7 blade,poly trans mounts,electric cooling fan,straight pipes loud and proud, Front disc conversion, 6" lift, Rancho RS5000 Shocks,Chrome Cragars
Put new bushings in my 79 j20 front springs that will be going into a SOA 84 Wagoneer. Paint to follow.
Where is my axle?
