Old 05-08-2007, 01:46 PM
mjs408 mjs408 is offline
My first FSJ
Bought myself a 79 J-20 360/th400/ part-time convert quadra trac.
Has an un-known lift on it, may be rancho, red shock boots and bushing,(rear block) idk. Also is the snow boss package came with plow that i might sell. Going to do floor pans, rocker, and cab corners. and may an m715 style box for it, and rebuild the 360
all for 1250, and its already hauled 230 dollars worth of scrap!!
Old 05-08-2007, 01:54 PM
CustomWag's Avatar
CustomWag CustomWag is offline
Welcome from Oregon! Good looking truck. Lots of good info here, have fun
Rick
84 Custom GW
360/727/208/d44f/AMC20r/3:31
Manual windows/locks/seats
Old 05-08-2007, 02:46 PM
jepj2000's Avatar
jepj2000 jepj2000 is offline
I saw this truck on pirate the other day. Glad to see you have made it to this board as well. Keep us posted on whats going on with the truck and what your plans are for it.
Rankin
1972 J2000: 304, T18, Dana 20, Dana 44s w/ 4.09s, Rear Detroit, 7.50-16s
1977 J10: 401, TH400, Quadratrac, partime kit, Dana 60's , 4.10s, welded rear, RS44044s SOA, 63" Springs inboarded, 36" Goodyear RT IIs
Old 05-08-2007, 02:49 PM
skeletor's Avatar
skeletor skeletor is offline
thats cool you dont see too many snow bosses around.
-bryan
1984 j10 LWB
1977 Cherokee chief wide track(sold)
2004 LJ
Old 05-09-2007, 02:59 AM
dngrs1's Avatar
dngrs1 dngrs1 is offline
Nice looking truck!
Part time QT? Unlock the front hubs and see if it moves, to be sure.
'77 J-10 '79 CJ-7
Arizona-The Rust Stops Here
Old 05-09-2007, 05:39 AM
I got the Willys....
Nice, I like it. You got a decent deal for $1250.
1971 Gladiator
Old 05-09-2007, 06:46 AM
grand_wag_85's Avatar
Murphy's Law Poster Child
Just becareful not to fry the diff
BTW-Nice J20!
'65 J2000
Old 05-10-2007, 12:41 PM
I think so, it looks like an aftermarket sticker laid over the factory one in the glove box, somebody might have just put hubs on it. I could be wrong
Old 05-10-2007, 12:47 PM
Chrome's Avatar
Chrome Chrome is offline
Ph.D in Redneckology
Welcome to the sickness.. ..I mean madness.. ...FSJ Family..yea that's it.
..,=====,o00o
//__l_l_,\____\,__
l_---\_l__l---0
lllllll0
_(o)_)__(o)_)--o-)_)___
Old 05-10-2007, 01:03 PM
Welcome to the Madness! Good lookin truck for 1250. The glovebox sticker on the shifter would indicate it had a part time conversion at some point, but many Quadratrac Jeeps have had the tcase replaced a time or two over the last 30 something years. It would be worth checking out just in case it is still a stock transfer case. If you have the switch in the glovebox turned to the left (counterclockwise with engine on) and the hubs unlocked, you should be able to spin the front driveshaft by hand if it is indeed converted.
Old 05-10-2007, 01:25 PM
with switch to the left (says 2wd) and hubs unlocked, front shaft doesnt turn???
Old 05-10-2007, 01:33 PM
The light in the instrument cluster (Emergency Drive) should be off in 2WD and on in 4WD. Are you sure the hubs released? Might want to roll it just a bit then check again.
Old 05-10-2007, 01:42 PM
It says part-time, also no light in the emergancy cluster comes on
Old 05-10-2007, 01:48 PM
If the front shaft does not spin freely when in 2WD and hubs unlocked, I would suspect shifter problems on the glove box vacuum switch or vacuum shifter or the Quadratrac is not converted. Try changing the rubber vacuum lines out and try it again. The ones that get the worst weather and wear are from the steel lines to the shifter on the transfer case.
There should be steel lines from near the firewall to the transfer case. If they are rubber all the way, then someone tossed them and the rubber lines could easily collapse with age and wear. Here is a vacuum diagram:
Old 05-10-2007, 01:54 PM
I know 4x4 works, tested it out one day last week. but I have driving 50+miles w/hubs unlocked, so they shouldnt be jammed(engaged) although I didnt coast in reverse.
Old 05-10-2007, 01:59 PM
Carl Rasmussen's Avatar
Carl Rasmussen Carl Rasmussen is offline
Wecome to the addiction
Carl Rasmussen
No more cable bills
Android TV box Full setup and configured $150 https://youtu.be/7bAm9RzIgms
Old 05-10-2007, 02:02 PM
Then my best guess is you do not have a part time conversion and you should leave the hubs locked to prevent damaging the limited slip differential in the transfer case. The only way to really know if it is converted (and trucks are easier than Waggys and Cheros) is to remove the inspection cover over the shifter and see what kind of shift collar is in there. There is a spring retainer nearest the vacuum diaphram on the shifter. Don't let that get away from you. You may need a light and mirror to do this with it in the truck.
This might help:
Much more Quadratrac info in a link in my signature.
Old 05-10-2007, 02:12 PM
or i could just swap in an d20 or np205 with a stick and be done with it!
Old 05-10-2007, 02:32 PM
Don't be fooled by others on the quality of a Quadratrac, when they work, they kick butt.
Changing tcase to D20 or NP205 - That requires:
  • a different adapter between the tcase and the tranny
  • change the tailshaft on tranny (tear down, overhaul)
  • w/NP205, frame crossmemeber modifications are probably required
Old 05-10-2007, 02:55 PM
skeletor's Avatar
find out what fluid is in it, if its atf its usually (not always) part time. if its anything else than chances are it hasnt been converted.
-bryan
1984 j10 LWB
2004 LJ
